non standard tires/wheels
Old Jul 2, 2018 | 10:29 PM
Gerard Radimaker's Avatar
Default non standard tires/wheels
I have come across a set of tires and wheels rumoured to fit 2004 and up jaguars. 255/35r20. I am currently running 235/50r17 stock on a 2005 S type 4.2 na. Other than being chrome Lexani wheels (a bit flashy),with Pirelli rubber with about 10k on them what problems am I going to incur running such a set up? The price is right and I could use new tires. Thought I would keep the stock wheels and run snows on them for winter.
Old Jul 3, 2018 | 01:56 PM
scottjh9's Avatar
I can say this by my own experience with my 4x4 truck...when you change from the factory size you need to tell the computer somehow so it can calibrate everything for the new size...other than that I guess you might have to deal with clearance issues...not sure...someone will chime in with more than I know...you might even search it...I used my solus pro on my 4x4 to input the new size...these jaguars, electronically, are finicky from what I have learned so far if you do not do your research first before modifying anything...hope this helps some
Old Jul 3, 2018 | 02:05 PM
leaping cat's Avatar
The difference is 3 %, it is a no-go.
Old Jul 3, 2018 | 03:23 PM
I do not understand. 3% difference in what? And what is a no-go?
Old Jul 4, 2018 | 12:51 AM
3 percent difference in diameter between the two tyres. This is way too much and you should not use it.
Old Jul 4, 2018 | 05:32 AM
JagV8's Avatar
There's a real risk the offset will be wrong.
Old Jul 4, 2018 | 10:21 AM
Default thanks
I no longer see a readily available "thanks" response so I will do it now by hand. The entire setup - 4 tires with wheels with less than 10k on the tires for an aking price of $250 US locally available seemed like a great value. I realize the 3% would affect the speedo and such but I had not considered the offset and possible stress factors. Probably not a great idea. On to new tires - should I start a new tire thread? Just kidding!
hoopics
F-Pace (X761) / C-X17
Apr 5, 2018 08:39 AM
JJLL
Apr 10, 2017 07:11 AM
worrasf
May 2, 2016 09:30 AM
sonicd0012
Nov 19, 2015 06:27 PM
deuceford
Nov 7, 2010 10:44 PM
