Odd Leak at coolant connection to engine
Old Jun 22, 2015 | 10:12 PM
Quantico's Avatar
Default Thermostat Housing and Outlet Leak
I have slow weeping leak in plastic Thermostat Housing and Outlet directly under EGR. It looks like oil, but could be coolant. There seems to be a hairline crack right at radius that very slowly weeps fluid, with engine hot/running. It is reddish in color, but doesn't steam/evaporate like coolant, which makes me think it's oil, but I could be wrong. I haven't taken it apart yet, but i assume it's one piece, not a seam at flange. It looks like maybe it cracked at radius when bolted/stressed. Anyone with ideas or similar experience, I'd appreciate hearing what you did. Could it be glued/epoxied/solvent welded in place? Thank you in advance.
2004 s-type 4.2 99k mi
Pic from part supplier. Have not removed mine yet. Looks like it's not quick job.
Old Jun 24, 2015 | 09:59 PM
WhiteXKR's Avatar
The plastic assembly develops hairline cracks and leaks orange coolant very slowly...it may not steam. The coolant can feel a bit oily.
Replace the entire assembly, which includes a new thermostat and temp sensor. This will only get worse and is a well know issue as they age. This will buy you another 10 years. I think it is a bit over $100. A patch is not the answer, and is playing Russian Roulette with the engine which is very intolerant of overheating should the problem worsen suddenly.
Old Jun 25, 2015 | 08:30 AM
Quantico's Avatar
Thanks WhiteXKR! Now that's the kind of succinct, sensible advice I love this forum for. I've GOT to replace housing now! So I don't feel like an idiot.... crawling back here later with with an overheated/blown engine! Everyone will rightly say "We told you ......."
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
montypeek
Sep 6, 2015 04:57 PM
TC Johnson
Sep 2, 2015 09:30 AM
