Oil Change leads to...cascade of problems
Old Nov 23, 2020 | 05:52 PM
jeffn's Avatar
Default Oil Change leads to...cascade of problems
Hi all, so a simple oil change by local and honest one man tech today lead to a downhill slide. 2 quarts low after ~ 1 year and 8k miles on the oil (he said it burning as there were n0 leaks), he saw a code on the dash (I have the parking brake disconnected so that one's there constantly), he saw a couple limp home codes which suggested throttle body (4.2).
Now, I have an infernal and incessant fast beeping from the left dash after he reset the codes. It occurs when underway. The car IS almost 14 but had 38k miles now. And a a topper, my 1 yaer old Yokos have worn out in front on the outside AFTER an alignment when installed...as least it's not a Honda. Any thoughts? And the battery was fresh this year also-it's almost a daily driver, never sits more than a few days.
Old Nov 23, 2020 | 08:47 PM
SinF's Avatar
Deal with one problem at a time. 2 quarts low after 8K miles isn't great but isn't horrible. I find some engines burn some brands of oil more. For example, my winter beater Subaru burns Mobil1 synthetic but not Penzoil Synthetic. So try a different brand and monitor consumption.
Premature tire wear is almost always alignment (or hooning, but you wouldn't be asking why then). Have mechanic check all suspension components for old bushings/play. Then do alignment. Bad alignment happens. Worn suspension happens.
Electrical and codes - good luck. Can't help you.
Old Nov 23, 2020 | 09:15 PM
jeffn's Avatar
Thanks for the talking-down. Oddly, the control arms were shot at 24k likely from sitting 200' form the FL ocean eating away at them.
Old Nov 23, 2020 | 10:01 PM
davidladewig's Avatar
What year, model, and engine do you have?
Old Nov 24, 2020 | 11:27 AM
abonano's Avatar
Never leave oil in for a year, whether dino or synthetic...
Old Nov 24, 2020 | 08:57 PM
jeffn's Avatar
That would help, wouldn't it. 07 4.2. Just turned 38k.
Old Nov 25, 2020 | 05:03 PM
User 42324's Avatar
Some 4.2's burn a little oil, some don't seem to. Keep an eye on your exhausts & if you notice one getting sootier than the other, get a compression test done as it could be an oil control ring on the way out.
Old Nov 25, 2020 | 05:42 PM
jeffn's Avatar
So you mean the bottom piston ring, correct? How badly assembled can these mills be with something major happening at 30k smiles?
Old Nov 25, 2020 | 06:01 PM
User 42324's Avatar
I wouldn't say they're badly built but there are certainly differences in oil consumption. I've seen a shot ring in an 80k mile car, so mentioned it as something to keep an eye on since you queried oil use in a 14 yr old car you've had for a year.
glenn's E
Mar 5, 2020 06:59 PM
Atlastajag1
Jun 14, 2016 02:18 PM
jiffy14
Jul 31, 2014 10:32 AM
jvegas
Feb 2, 2008 09:36 AM
JohnBurns
Oct 10, 2006 09:55 PM
