oil in coolant reservoir
Old Jul 17, 2012 | 11:28 AM
03Jag4.2Stype's Avatar
Default oil in coolant reservoir
Has anyone ever had this issue?? Any help will be greatly appreciated. Thank you!!
Old Jul 17, 2012 | 12:52 PM
tbird6's Avatar
It does not sound good!! Any other things acting up?? I would test the coolant for combustion gases as that is simple and quick but generally this means you need a new engine.
Old Jul 19, 2012 | 03:49 AM
I had also heard it could be the head gaskets or intake manifold?? The car was running perfect but I stopped using it when this happened.
Old Jul 19, 2012 | 04:16 AM
Oil in the water is never a good sign. I'm assuming you can dismiss any chance of accidental contamination?
It can be a crack in head or block between an oil and a water passage. Very often it's the head gasket. A cylinder compression test will give a better indication of gasket failure.
Old Jul 19, 2012 | 01:24 PM
Robert Page's Avatar
Def head Gasket gone! If you did not put the oil in there a Gasket it is. Not the end of the world as long as you did not drive it too much after it happened. Will need Head skimming, gasket repair and worse of all internal clean up! You will not need a new engine as long as you did not cook it completely but you will need a partial rebuild. Do not drive the car until it is checked.
Old Jul 20, 2012 | 06:20 PM
Thank you so much guys for your input..my car has now been sitting since November. I suspected the head gaskets from the beginning. I bought them but have yet to find someone qualified that won't charge me a fortune. If anyone else has any input or prior experience please share. Once again, thank you very much!!
Old Jul 20, 2012 | 06:34 PM
If you're looking for advice on how to DIY, then you should do a forum search or start another thread on 'head removal'.
If you're looking for a local mechanic, location = USA isn't going to get much response from members. Asking for recommendations near to W****** might help.
Old Mar 27, 2022 | 07:46 AM
Brogi12's Avatar
Default Not head gasket
Usually, oil in reservoir is usually caused by a blown oil cooler not the head gasket. Common problem in jaguars
Old Mar 27, 2022 | 09:20 AM
S-Type Owner's Avatar
Welcome. The post you replied to is nearly ten years old... Hopefully the OP has his problem sorted by now.
You might want to stop by the New Members forum and post a brief "intro"... It is the expected thing to do and helps you to gain additional site priv's. The forum can be found here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Mar 27, 2022 | 03:58 PM
Sportston's Avatar
I agree, particularly if you have a Porsche 944.
Rivguy
Dec 4, 2020 07:55 AM
KarimPA
Sep 12, 2015 08:15 AM
Per
XJ40 ( XJ81 )
Sep 11, 2015 02:01 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
