Oil in the intake 3 liter
Old Jun 29, 2025 | 12:55 PM
Robert Laughton's Avatar
Default Oil in the intake 3 liter
Hello,
I have the upper and lower intake off, attempting to reseal everything to solve a code.
I was surprised to find a lot of oil behind the lower IMT valves.
Then I was researching here, and read Joyce'sJags post
https://www.jaguarforums.com/forum/s...ics-faq-32135/
and they found oil there too. Do we both have a PVC issue, or is this normal? My 2006 does not have the black box catch can under the lower intake, only has 2 hoses and 1 valve.
The IMT's have the new green seals, and I'll do the plugs.
Is the oil normal?
Thanks,
Rob
Old Jun 30, 2025 | 11:34 AM
kr98664's Avatar
My '02 V6 had oil collected by the IMT valves, too. The plenum is a different design, but still the same end result. Doesn't seem to be causing any trouble.
Old Jun 30, 2025 | 04:19 PM
h2o2steam's Avatar
Think it is pretty common........happens on the X-Type 2.1, 2.5 and 3.0 engines too.
Even my 4.2 XJ V8 gives the occasional blue puff at start up (once every 6-8 weeks) which I think is just some condensate build up getting occasionally pulled through.
A catch can generally solves the build up if you are concerned.
Old Jul 1, 2025 | 06:56 AM
Thank you Mark and Carl.
I have new gaskets coming, and will put this back together.
Cheers,
Rob
JagScott
Mar 10, 2012 03:30 PM
03Xtype
41
Feb 19, 2012 02:55 PM
bulkmail07
Jan 31, 2012 04:31 AM
cleveland
Jun 7, 2010 05:52 AM
joycesjag
Mar 14, 2009 04:43 PM
