Oil on spark plugs
Old Jun 9, 2009 | 11:26 PM
willsmith11111's Avatar
Default Oil on spark plugs
Ok fellas (and ladies), I seek your expertise. I have a 2003 S Type R. I took out two of my spark plugs today and there was oil in the chamber where the plug sits and also there was oil all over the end of the plug. The oil was clean and I recently did an oil change. I am thinking that I should have the valve cover gaskets and the head gaskets replaced. I only checked 2 of the plugs on the passenger side but I will also check the drivers side because I assume the problem is the same on that side.
Do you think this repair should eliminate the problem or do you think it may be something even worse. Thanks for any opinions you may have.
Old Jun 10, 2009 | 01:48 AM
wazari's Avatar
It's your valve cover gaskets. There are "ring" gaskets that are supposed to keep oil out of the spark plug wells that always fail after time. No need to change head gaskets.
Old Jun 10, 2009 | 02:11 PM
Thanks. I ordered new gaskets and plugs and I will get them changed as soon as they get here. I'm going to have a mechanic change the gaskets because I don't want to mess it up.
cissdm
May 3, 2016 06:02 AM
caveforce
38
Nov 16, 2015 10:19 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
