Old Topic - New Twist
Old Oct 5, 2010 | 08:34 AM
hmaster1's Avatar
Default Old Topic - New Twist
Sorry to bore everyone, but I need to get some input to hopefully avoid an expensive repair.
I own a 2003 S-Type V-6, 3.2, approx. 70K miles. That "resonating" or "whine" has developed in the rear end. We have done all the trial and errors to narrow it down without success (ie., changed fluids, moved wheels). The one deviation from the other postings I have read is that we cannot recreate the noise while the car is on the lift.
We have been hoping it is just the wheel bearings, but after reading all the posts related to a rearend noise and the TSB #205003 (installing new axle assembly & axle housing bushing), I am looking for more opinions before spending the money on the wheel bearings.
Thanks.
hmaster1
Old Oct 5, 2010 | 08:41 AM
carelm's Avatar
I had my rear differential replaced last year under warranty. The dealer was able to reproduce the problem on a lift. If your technician can't reproduce the noise, then I would be inclined to think it was a bearing issue.
Old Oct 5, 2010 | 10:28 AM
Iluvmy05STR's Avatar
hmaster1, what type of diff fluid did you use? Did you use the recommended stock fluid or did you try something with an additive?
Old Oct 5, 2010 | 10:47 AM
hmaster1's Avatar
We used the manuf. recommended stock fluid.
Old Oct 5, 2010 | 10:48 AM
hmaster1's Avatar
If we go the way of changing the bearings, does anyone know where I can purchase pre-pressed rear hub with bearings or are they only available separately?
Thanks.
Old Oct 5, 2010 | 10:56 AM
JagV8's Avatar
Worth checking with a jag franchise but I think they come complete with those.
NS2000XKR
Jan 1, 2017 10:41 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
CaptainHam
Oct 1, 2015 02:01 AM
