P0174 - Jag 2005 S - 3.0 Freeze Frame
Old Aug 24, 2016 | 12:43 AM
2005-Jag's Avatar
Default P0174 - Jag 2005 S - 3.0 Freeze Frame
I am thinking of buying this car and can't do any work before I buy. I have reviewed several post and was hopping with the information below maybe someone could point me in the right direction.
The car also needs tires and brakes it has been in one accident front end. This has been repaired. It a California Car so not rust.
With all this what is the car worth too? Anybody??
Are there any major problems to watch out for???
Vehicle: 2005 JAGUAR S-TYPE
Engine: V6, 3.0L; DOHC
Mileage Reported: 93,000
Freeze Frame Information
Parameter Description
Results
Description DTC for which Freeze Frame was Stored
Result P0174
Description Fuel System 1 Status Result Closed Loop
Description Fuel System 2 Status Result Closed Loop
Description Calculated LOAD Value Result 30.98 %
Description Engine Coolant Temp Result 190.40 °F
Description Short Term Fuel Trim - Bank 1 Result 13.28 %
Description Long Term Fuel Trim - Bank 1 Result 10.16 %
Description Short Term Fuel Trim - Bank 2 Result 11.72 %
Description Long Term Fuel Trim - Bank 2 Result 14.84 %
Description Fuel Rail Pressure Result 55.69447 psi
Description Intake Manifold Absolute Pressure Result 18.36 inHg
Description Engine RPM Result 1,808.25 rpm
Description Vehicle Speed Sensor Result 60.89 mph
Description Ignition Timing Advance #1 Cylinder Result 35.00 °
Description Intake Air Temperature Result 68.00 °F
Description Air Flow Rate Mass Air Flow Sensor Result 2.62 lb/min
Description Absolute Throttle Position Result 16.47 %
Old Aug 24, 2016 | 12:47 AM
2005-Jag's Avatar
Stored Codes
P0174
System Too Lean (Bank 2)
Pending Codes
P1111
System Pass
Old Aug 24, 2016 | 06:25 AM
JagV8's Avatar
May be an air leak. Many many threads about them.
Old Aug 24, 2016 | 01:59 PM
joycesjag's Avatar
2005-Jag, your lucky day:
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Old Aug 24, 2016 | 06:05 PM
gm_jim's Avatar
Could also be an exhaust leak before the first O2 sensor on bank 2. Usually the pipe to exhaust manifold. That was my issue - tightened it up and the code went away.
hiltoncam
Dec 12, 2021 06:54 PM
ALLEN68
Aug 28, 2018 11:55 AM
Lorraine Burke
Sep 15, 2016 10:49 PM
DAN L
Jul 27, 2016 07:56 PM
Lothar52
Jul 27, 2016 08:30 AM
