P0333 Code - Which knock sensor?
Old May 4, 2015 | 07:15 PM
ATLmike's Avatar
Question P0333 Code - Which knock sensor?
Hey folks, I'm having a hell of a time trying to figure out which part I need for my 2003 S-Type 3.0 Sport. I'm getting MIL code P0333 and P1111. I'm pretty sure that's telling me to replace the knock sensor. I'm just having a hard time finding the correct part. Is it the top knock sensor, or the one on the side? Should I replace both while I'm at it? I've narrowed it down to part #'s XR835380 (side) and AJ85676 (top). Please advise, thanks.
Also, what is a reasonable number of labor hours required to replace this? Trying to avoid an outrageous bill from my mechanic. Any and all advice is greatly appreciated.
ATLmike
Old May 4, 2015 | 09:35 PM
motorcarman's Avatar
P0333 is BANK 2
Here is the DTC guide for your car.
bob gauff
File Type: pdf
Old May 6, 2015 | 02:52 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Replace them both IMHO. If one has failed, it's probably only a matter of time before the other one goes. One of mine failed at around 85K miles, so I opted to replaced both of them, and then also replace plugs, coils, gaskets, filters, and do some other engine work that needed to be done around same time.
The knock sensors are not expensive - I paid about $45 total for both at RockAuto.com last year.
Old Jun 24, 2016 | 10:26 PM
ndy4eva's Avatar
How easy is it to replace the knock sensors? I don't need to replace the plugs or gaskets (already done them).
I'm getting P0333 codes.
Thanks,
Old Jul 2, 2016 | 05:17 PM
Originally Posted by ndy4eva
How easy is it to replace the knock sensors? I don't need to replace the plugs or gaskets (already done them). I'm getting P0333 codes. Thanks,
I didn't do the work myself so I can't answer your question firsthand. But I understand that one of them is fairly easy to access but the other one requires removal of some parts to get to it. This is why I opted to have other engine work done at the same time. My approach is - If you're paying a mechanic to remove and replace parts to repair something, then you might as well have him do other maintenance tasks while he's got things apart anyway, killing 2 birds with 1 stone so to speak. Sorry I couldn't give you a better answer.
mrplow58
Jan 21, 2024 05:53 AM
Steviedee1st
Nov 28, 2023 06:32 PM
Shawn Svacha
Feb 6, 2022 04:53 PM
caveforce
38
Nov 16, 2015 10:19 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
