P1587 error code how to fix this code
Old Sep 23, 2019 | 02:41 PM
Chris Benyo's Avatar
Default P1587 error code how to fix this code
2000 s type 4.0
Old Sep 23, 2019 | 07:03 PM
motorcarman's Avatar
Page 55 DTC guide for 2000MY X200
PCM to TACM redundant control circuits (TACM
pins 2, 3): open circuit, high resistance, short
circuit
TACM ground circuits: open circuit, high resistance
TACM Failure
File Type: pdf
Old Sep 23, 2019 | 09:06 PM
Be aware that if you need a replacement throttle assy, you can use either 3.0 or 4.0 X200 throttle. (I don't think the X202 is compatible)
I just installed a used 2001 3.0 S-Type throttle on a 2002 4.0 S-Type engine today.
(I got it REALLY CHEAP)
The only difference is the coolant pipe for warming the throttle to prevent icing under certain circumstances.
The 4.0 has the coolant pipe in the manifold adapter and the 3.0 has the coolant pipe on the throttle itself.
I just bent the pipe ends so they would not interfere with the ones on the manifold. Bolted the throttle up and plugged it in!!!!!!!
DONE.
The 4.0 won't work on the 3.0 because there would be no coolant flow pipe on the 4.0.
It will function but it might 'ice-up'!!!
bob
Old Sep 29, 2019 | 09:22 AM
XJsss's Avatar
Posted in wrong forum
Old Apr 28, 2020 | 10:54 AM
Fraser Mitchell's Avatar
These people all with the same name (Charlie Allthumbs), seem to get around far too much and its always just before you buy a car. They need to be on permanent lockdown !! Don't forget the posts on the need to check-out your pads and discs; they don't last forever.
Old Apr 28, 2020 | 01:45 PM
JagV8's Avatar
Wrong thread?
Jon89
Jan 29, 2019 11:44 AM
jelu02
Jun 8, 2018 08:09 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
Fermanaghman
Oct 30, 2012 08:34 AM
