Park Brake Cable path
Old Jul 12, 2021 | 03:45 AM
essomba421's Avatar
Default Park Brake Cable path
Hi all,
I've a problem with my park brake cable path. It's blocked on the nut of stabilizer bar link. If I move it then it comes back automatically here.
Obviously, it's damaged:
I tried to flip the piece on top of the stabilizer bar link but I'm not convinced:
So my question: what is the path of this cable ?
Thanks,
Laurent
Old Jul 12, 2021 | 06:31 PM
xalty's Avatar
it rides on top of a rubber pad mounted on top of the sway bar link nut. your path is correct
they are all worn in that area even with the pad
Old Jul 13, 2021 | 02:31 AM
essomba421's Avatar
Thanks for your answer.
I looked at the part numbers on the SNG catalog but unfortunately these parts are unavailable.
Old Jul 15, 2021 | 02:06 AM
MCFastybloke's Avatar
I made a packing from some nylon bar, cut a length,made a dome on the top with a grinder,drill a pilot hole and use force to wind it on.
EDIT: would a suitable dome nut ease the issue?
Old Jul 15, 2021 | 05:18 AM
essomba421's Avatar
I think about a dome nut but it will not prevent the cable to move away. My problem is the French MOT which states the cable is not well attached. So I'm trying to figure out a way to attach it.
Higgins
Sep 18, 2020 11:03 AM
35olds
Apr 21, 2020 11:50 AM
misplaced1954
Nov 6, 2019 05:41 PM
TheWarlock
Sep 18, 2014 02:48 PM
bocagq45
Jun 3, 2013 06:12 AM
