Parking Brake Fault ‘ / Loss of Power / Not cranking
Hi all. ‘ Parking Brake Fault ‘ / Loss of Power / Not cranking
S Type 2.7 D/ 11/2007
Yesterday I was driving after a nice car spring clean, just had service, and passed its MOT, had no recent obvious noises or anything to indicate a current fault. Nothing ‘suspicious’, basically driving like we all know a well taken care Jag, purring along nice and gracefully.
Suddenly and abruptly at approximately 25 MPH, ‘ Parking Brake ‘ Fault displayed in Yellow on the Dash. > The Car then slowed down quickly then drastically ( it seemed )
> lost power, steering went very hard > then total engine loss.
Just about managed to steer the car into the cerb of a live and fast moving lane.
The car wouldnt crank / Turn over >nothing was responding
just> ‘ parking brake fault’ on the dash.
The Parking brake woulnd’t disengage
RAC turned up, and gave me the following readings from The computer -
‘’ RAC DIAGNOSTIC SYSTEM
System Type: PARKING BRAKE Name: PBM - PARKING BRAKE CONTROL MODULE DTC: C1D14,Ignition status DTC: C1D15,Brake switch status DTC: U0100,Lost communication with ECM/PCM "A" DTC: U0155,CAN: communication fault with IC (Instrument Cluster)
System Type: AIRBAG ELECTRONICS (SRS) Name: ARM - RESTRAINTS CONTROL MODULE DTC: 0000,unknown
System Type: CENTRAL ELECTRONIC UNIT Name: DSM - DRIVERS SEAT MODULE DTC: B1940,Seat Memory Position Out Of Range. DTC: 0000,unknown
System Type: NAVIGATION SYSTEM Name: NAV - INTEGRATED NAVIGATION UNIT DTC: 0000,unknown
System Type: SOUND SYSTEM Name: FEM - FRONT ELECTRONIC MODULE DTC: 0000,unknown
System Type: SOUND SYSTEM Name: FETM - AUDIO UNIT DTC: B2477,Control module configuration incompatible DTC: U2008,Audio telephone is not responding. DTC: B2888,Audio system media fault DTC: 0000,unknown
System Type: SOUND SYSTEM Name: REM - REAR ELECTRONIC MODULE DTC: 0000,unknown
System Type: DOOR MODULE Name: DDM - DRIVER DOOR MODULE DTC: 0000,unknown
System Type: AC SYSTEM Name: ATC - AUTOMATIC TEMPERATURE CONTROL DTC: U2520,IPC (instrument panel cluster) - missing message DTC: U2521,Missing the CAN message from the ABS DTC: B1
The RAC mechanic was with me inspecting the car for one hour, a lovely man, but gave some odd advice,
1. It must be gearbox fault.
2. Wiring loom.
I immediately thought ‘battery issues’ as i had a similar issue with a very old 1999 S type,
he tried to jump start, but it wouldnt crank, he said it had enough voltage to start as my battery was reading about 12 Volts, is 12 Volts enough to start an S-Type Diesel 2.7?
I am not confident that his view on the gearbox is accurate.
could it be throttle body sensor related?
I need the car as I use it sometimes for my volunteering at my local hospice as a driver for patients, and im due to make some pickups this week.
ive read the forum and can find similar posts, however, a lot of the posts seem to pertain to the same issue apart from mine is not cranking,and I have no power - subsequently i cant go through the braking re-calibration process which i have read about
i recently have had new discs and pads all round. ( is this significant )?
(about 10 minutes prior to the car loosing power and displaying the ‘ parking brake ‘ fault light, I was trying to use the On Board Sat Nav, whilst in the sat Nav settings, there was an option for ‘ calibration ‘ which i assumed was for the sat nav or parking or distance settings or just random SatNAv update settings and it needed its setting changed. Which I pressed.
since then my mind has been playing tricks, wondering if by pressing this i have somehow ‘activated’ the parking brake calibration from within the sat nav settings, is this possible, is there any type of settings inside the satnav menu that can influence the parking brake and make the car to loose power) ?
i have also lost the radio and sat nav code> its asking for settings.
does the symptoms sound familar to anyone?
does anyone know of an Essex / Kent mobile with a Jag Computer JIT system?
My advice to you all. =
I was on a hard and live lane, quite scary to be honest, and I didnt have my Warning Triangle, only my yellow jacket! always remember your triangle, ! or to be extra safe, have 2 in the boot.
even with my hazzards on and yellow jacket cars were whizzing past at high speeds
( some were obviously young and dangerously inexperienced to be driving so close to my veichle ) , many cars were using there horns at dissaproval of me having my hazzards on, and them having to swerve around my car,...
with 2 warning traingles if this happens again i would put one about 50 meters from the car, and then one 10 meters away.
hopefully this wont happen to you, but its always better to be prepared in case like me you break down in a live, fast lane. And irrespective of our experience with safety, all it takes is one driver to smash into us .
Also, be prepared for the RAC to take 90 minutes to arrive, then another hour for the truck to come with skates, ( because the parking brake couldnt be disengaged )
warm coat / water and gloves in a bag in the boot is also important too!
if your a pensioner or have any health problems, then a spare warm coat / hat /gloves is a must!
any guidence or help is much appreciated
kind thanks Jeff
Received 2,255 Likes
Received 2,579 Likes
It would seem the battery may be suspect as minimal voltage across the terminals with the engine off should be 12.2 volts. If the voltage according to the RAC is 12 volts, that may be your starting point.
A diesel variant may require more power when cold to get the engine to crank and run.
Received 1,410 Likes
+1 and Bingo to the need for battery charge or replacement as neither your 12V nor 12.2V is adequate. Unless you are the original owner or have documented proof of battery replacement (and my 2007 2.7L TTD was fitted with a 2006 manufactured Varta) yours may be the original - and that makes it 10 years old!
The 2006 onwards 2.7L TTD should be fitted with the higher spec battery and 12.6V is considered the minimum threshold voltage - measured after an all night rest following being full charged. Around 12.3V should crank and start engine, but anything less than 12.6V will throw a succession of well known faults - all well documented here - parking brake fault; cruise cannot engage; ABS fault etc etc etc . . .
1) Suggest you search this forum for "Battery 101 . . ."
2) Suggest you get one of the new Smart Charger (Battery Tender).
Cheers,
Ken
Cheers,
Ken
philwarner
10-16-2016 04:38 AM
