Passenger window going down on it's own!
Old Feb 9, 2024 | 08:50 AM
mikesbaron's Avatar
Default Passenger window going down on it's own!
2003 V8/base. .
The other day a stereo installer took off my front passenger side door panel in order to test the door speaker (all was well), but ever since he put the door panel back on the window will roll down on it's own everytime I turn the ignition on or off. The day after I get into my car in the morning, turn the ignition ON and the window rolls down on it's own and the master switch on the driver's door has no effect. I had to cycle the key OFF and ON in order to get the window to roll up. Then yesterday several times when I turned the igntion OFF, the window rolls down on it's own.
What do you guys think, seen or heard this before?
Old Feb 9, 2024 | 09:29 AM
clubairth1's Avatar
Community Influencer
Seems related to what the stereo guy did?
I would take it back and let him fix it?
Old Feb 9, 2024 | 09:48 AM
scrannel's Avatar
Could your stereo guy have messed up that door up/down switch?
Old Feb 9, 2024 | 11:51 AM
kr98664's Avatar
If the switch is okay, maybe a wire got pinched and has created a bare spot rubbing against ground. Whatever happened, the timeframe certainly points to a new problem created at the stereo shop.
Until you can back there, you may be able to pull a fuse to temporarily disable the window in the closed position.
Old Feb 12, 2024 | 09:20 AM
mikesbaron's Avatar
Thanks for the points. The window is wackier now than ever before, it will randomly roll down while driving at freeway speeds-I'll have to stop and cycle the ignition to get the window to go up. Yeah will check out the actual switch and wiring.
Old Feb 12, 2024 | 10:53 AM
kr98664's Avatar
For the right front window, pull fuse F6 in the trunk. That should disable it until you have time to investigate further.
Old Feb 13, 2024 | 05:54 PM
davidladewig's Avatar
The ghost of Jaguars past? Maybe?
Old Mar 1, 2024 | 07:57 PM
Catmobile's Avatar
I think that it might be haunted too. If you can't find a damaged wire, switch, or connector it might be true. At least it's just a mischievous spirit, not anything dangerous. If things don't get settled by the next full moon, I'd suggest an offering at the rising of the next full moon. First paint spots all over yourself and in a fire make an offering of some cat fur and a two dollar bill while singing "The Long and Winding Road." It's been keeping my car in tip top shape for years.
Old Mar 1, 2024 | 11:37 PM
kr98664's Avatar
Originally Posted by Catmobile
I'd suggest an offering at the rising of the next full moon. First paint spots all over yourself and in a fire make an offering of some cat fur and a two dollar bill while singing...
I am confused. I thought that was the start of the official factory procedure for bleeding air from the cooling system.
Old Mar 2, 2024 | 04:02 PM
Catmobile's Avatar
It works for that too. The Official Factory Procedure is to put on your Druid regalia after painting the spots on yourself, in the fire offer a minimum of 10 cubic centimeters of cat fur, and a fifty dollar bill. I was just suggesting the DIY version, of course it's cheaper. If you want to be hands on, you can squeeze the hoses for a while after you are done with your offering.
Old Mar 2, 2024 | 04:12 PM
Catmobile's Avatar
Oh, I forgot in the Official Factory Procedure you should still sing "The Long and Winding Road" while performing the offering, of course.
Old Mar 2, 2024 | 04:39 PM
scrannel's Avatar
So complicated. Get naked, sit in the driver's seat, squeeze a dead mole over your head. That will do it. Trust me.
Old Mar 3, 2024 | 09:31 AM
clubairth1's Avatar
Boy no wonder I am having problems!
I had no idea it was this complicated either!
Old Mar 3, 2024 | 03:26 PM
Catmobile's Avatar
Thanks for the tip Scrannel, it's hard to get the fire going for the offerings when it's raining. Do you still have to paint spots all over yourself, or is that optional?
Old Mar 3, 2024 | 03:44 PM
scrannel's Avatar
They used to be sticklers about the spots -- no one seems to care any longer. Just so long as you have a nice, fresh mole to squeeze.
Old Mar 3, 2024 | 03:55 PM
Catmobile's Avatar
One other thing that might be worth a try is to pull the fuse for the front passenger window for a while to reset it, maybe do F5 for driver's side too. It is in luggage compartment fuse box, F6, Cartridge type fuse, 20A, Blue. A while ago my rear tail lights were haunted and after my offerings and changing light bulbs weren't working, I pulled all the fuses related to the rear tail lights to reset things and problem solved. So even the tail lights are computerized, maybe the window controls are too.
Old Mar 3, 2024 | 03:57 PM
Catmobile's Avatar
Oh Scrannel, is it ok to freeze moles to save for the future, or do they have to be fresh?
Old Mar 3, 2024 | 04:24 PM
kr98664's Avatar
One other thing that might be worth a try is to pull the fuse for the front passenger window…
Hey! Let’s stay on topic, please. We were discussing the finer details of Jaguar incantations.
Old Mar 3, 2024 | 05:04 PM
Catmobile's Avatar
Well my experience has been that the spirits can be fickle, sometimes offerings work great, sometimes not so good. I guess you really have to be positive and confident when you perform them. Incantations are a bit more complicated. Genuine Jaguar mechanics go through years of training in Druid rituals and incantations, too much for the uninitiated like me, I just stick to simple offerings.
Old Mar 3, 2024 | 05:29 PM
scrannel's Avatar
Time for a pilgrimage I'm afraid...
