Pentosin AFT1
Old 03-17-2013, 09:14 PM
LoganWolf's Avatar
Default Pentosin AFT1
Any thoughts or has anyone tried Pentosin ATF 1? The NAPA by me just started carrying it. It says it is compatible with my ZF trans.
Just wanted to get some advice before I dive in.
Old 03-18-2013, 07:58 AM
TonyX's Avatar
Have you considered Mercon SP as an alternative? It's readily available through Ford dealers and others have used it in place of the ZF Lifeguard 6.
Jon89's Avatar
Received 4,309 Likes on 2,827 Posts
Search for the ATF drain-and-fill threads from member "ccc". I believe he chose Pentosin ATF when he did his drain-and-fill about three years ago....
Old 03-18-2013, 11:52 AM
tbird6's Avatar
It's been posted many times but I use Claus at CTSC. Don't forget to do the full service. He has the kits at a good price. I just used the proper ZF fluid since it's come down in price a good bit.
Do you know about the other issues?? There is more to it than a simple fluid change. Reasearch it before you dive in. It will be worth your while!
The CTSC - ZF Parts
GT42R (03-18-2013)
Old 03-18-2013, 08:56 PM
Received 7,918 Likes on 4,785 Posts
Pentosin ATF1 is for the 5HP24 (NOT the 6HP26)
bob gauff
plums
General Tech Help
01-29-2020 06:28 AM
Wes Steenrod
09-06-2015 06:52 PM
whyhellothere
01-03-2015 07:14 PM
Tanman
04-07-2014 03:44 PM
Spurlee
07-23-2011 09:16 PM
Quick Reply: Pentosin AFT1
