performance problem
Old May 24, 2017 | 06:16 PM
Chason's Avatar
Default performance problem
Hi all
i have a 54 plate s type 2.7 diesel. Everything has been fine until last week when I was driving home. Engine was at temp as normal when I went to accelerate no power. Looked down at dash and I had performance restricted
problem being there were no warning lights on anywhere just the message
turn it off and back on it was fine. 8 later exactly the same thing
car had major service and cam belt 4!weeks ago by a local jaguar master tech
no faults on them cars on board diagnostics and I can't get me obd2 reader to talk to the car
any ideas
thamks
paul
Old May 27, 2017 | 04:11 PM
Ducmon's Avatar
Which obdII device are you using because I have had problems with an elm327 version 2, it worked on some cars but not on others.
So just see if you can get another score reader and try that.
Old May 28, 2017 | 10:56 AM
Chason's Avatar
Default Elm
Well just plugged in with elm and my laptop connected fine. But guess what. No
error codes of any description. Think this is gonna be a weird one
thanks
Old May 28, 2017 | 03:11 PM
Ducmon's Avatar
I would start by looking at the battery, it has to be 12.6 volts. then I would go to the fuel trims
They might show you if something is not right, The long term fuel trims have to be around+ or - 20% from the 0 line to set a code so if it different from that it may show that you have a problem
Old May 28, 2017 | 03:13 PM
Chason's Avatar
Default Fuel trims
are they checked while
runnimg
or
om a journey with laptop plugged in
thanks
paul
Old May 28, 2017 | 03:54 PM
Ducmon's Avatar
You have to start the engine. The short term will fluctuate that is normal, it's the long term that are of interest
Old May 28, 2017 | 05:22 PM
Chason's Avatar
whats the best software for this
Old May 29, 2017 | 02:56 AM
Ducmon's Avatar
Hi,
I use this program http://www.outilsobdfacile.com/software-eobd-facile-elm327.php
Test version.
I set it up to use the graphs in additional features.
then I use the short-term bank 1 ((lambda sensor) long-term 02 sensor bank 1
I also set it up to read the bank 2 at the same time.
watch this video and it help you understand what you are looking at.
https://youtu.be/5WnM_NsOtd8
