periodic overheating
Old Apr 20, 2014 | 02:45 PM
slash's Avatar
Default periodic overheating
So, after my 2000 S type has been sitting for a while, after it warms up to operating temps, the temperature will spike to hot. After a short period, it quickly moves back to nominal. Then often it will do it again, only to quickly move back to operating temperature. I assumed that my thermostat was sticking shut, so I got a new one and replace the old one. The first time I drove it afterwords, the car did the same thing, spiking to hot, then dropping back to norm. Anyone got any insight on what the problem is? I certainly don't want to blow head gaskets or do any other serious damage.
Old Apr 20, 2014 | 03:13 PM
police666's Avatar
How do you know it's overheating? Are you monitoring via obd or the cars temp gauge?
Old Apr 20, 2014 | 04:01 PM
QuartzSTypeR's Avatar
How quick is it jumping and going back down? If its just a couple of seconds, you may have air pockets in the cooling system. If it takes a bit longer, I would wonder if your low speed fan isn't working properly.
Old Apr 20, 2014 | 04:10 PM
slash's Avatar
It shows on the cars temperature gauge, and then I get a warning on the control panel of high engine temp. It usually goes down pretty Quick but sometimes takes a couple of minutes to move. Once it starts moving, it goes back to normal in just a few seconds
Old Apr 20, 2014 | 08:52 PM
LoganWolf's Avatar
I had a similar problem. It ended up being the thermostat and later the housing. If u do end up replacing yours, I would recommend getting one from Jag. The Stant I got from advance auto did not open and close in correctly. Good luck.
Old Apr 24, 2014 | 03:36 PM
slash's Avatar
Default update
Ok, yep, it was indeed a cracked thermostat housing that was giving me issues. I also replaced some of the old hosing that was suspect.
Old Apr 24, 2014 | 03:39 PM
JagV8's Avatar
Thanks for the follow up, others will have this.
jagent
Jun 5, 2022 02:18 PM
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
