Preparing for a Trip to France....
Old Mar 31, 2015 | 03:06 PM
jpvd's Avatar
Question Preparing for a Trip to France....
getting ready for a roads trip to france in the next couple of months with the s type...v8 4.0
been getting a few of thr jobs done ready.
So far:
  • Fitted new radiator (old one blew on the motorway and left me stranded on the hard shoulder for 4 hours - cut a long story short the AA apologized by sending a Jaguar mechanic who replaced the radiator for free at my home the next day!)
  • Fitted new water pump - the old one was plastic, but was in perfect condition - new pump was also plastic because apparently they have stopped using metal since if it breaks it destroys the engine, where as a plastic one doesn't.
  • Fitted new rear discs and pads and sliders (found one seized solid)
Things left to do (getting her in the shop for these):
  • New rear tie rod bars (looking a little tired)
  • New driveshafts (shafts are fine but threaded ends had rusted badly and crumbled away when i did the discs, so want to get them swapped - bought some secondhand units to install
  • Cam cover seals need doing (again) own fault for buying the cheap seals the first time round - sticking with the jaguar OE this time round
  • Checking timing chain top tensioners and replacing if required.
Can anyone recommend anything else which i should check over or maybe replace prior to going? Reckon i have pretty much covered all the weak points, etc.
cheer
paul
Old Apr 1, 2015 | 01:31 AM
A pretty sweet list.
I will assume that the serpentine belt was renewed when the pump was renewed?
A trans fluid drop and refill will do no harm.
Apart from that a full tank of go juice, some nibblies for you, and hit the bitumen.
jagtoes
Oct 14, 2015 06:15 PM
LnrB
Oct 13, 2015 12:45 AM
Joe Gandalf
Oct 1, 2015 01:16 AM
goingjag
Sep 30, 2015 09:27 PM
mrplow58
Sep 30, 2015 08:56 AM
