Question about parking brake
Old Nov 21, 2019 | 09:39 AM
2jags1993's Avatar
Default Question about parking brake
I was recently at the local junkyard to get parts for my x308 and I came across a 2006ish jaguar s type with some aftermarket rims that didn’t look to bad the issue was I couldn’t get them off because the rear tires would spin freely. Is there a way to override the e brake and get the rims off
Old Nov 21, 2019 | 10:03 AM
M-e-l-l-o-w's Avatar
Get a long strong rod as thick as you can that can fit through one of the holes in the wheels.
Wrap the area where it will be in contact with the wheel with a rag so it does not damage the wheel and push it through.
Turn the wheel until the rod jams on the suspension and then undo the lug nuts.
Mellow
Old Nov 21, 2019 | 11:24 AM
motorcarman's Avatar
The X308 was the last Jaguar sedan to use the 5 on 4 3/4" bolt pattern. The S-Type uses a FORD bolt pattern (metric).
bob
Roldano
Dec 17, 2018 07:51 AM
iownme
Jul 22, 2012 08:33 AM
Chromey35
May 9, 2012 02:17 AM
mphy98
Nov 23, 2010 12:43 AM
IrishXtype
Sep 22, 2010 01:14 PM
