Questions from a STR owner...
Old Aug 18, 2008 | 09:19 AM
MidGaSTR's Avatar
Default Questions from a STR owner...
Hopefully this will help out alot of people. Please try to include information for all models (3.0/4.2/R)
If admins want to clean this up or have suggestions for me please let me know. Forums are a wealth of information.
1.) What is the correct way for replacing the brake pads. Any special tools for the parking brakes? What pads do you use. What about rotors?
2.) A good list of OEM and Aftermarket manufacturers? Is there anyway to raise the revlimiter? Any cpu flashing tools? (techs please respond on this) Will stand alone's work? How well built is the engine? How much boost can it handle? Is there headers? Affordable cats? (6k for cats is retarded.)
3.) Proper oil change procedures? How many qts of oil is needed for all models? Suggested filter? Whats the suggested oil change interval? Does the car tell you when to change the oil? Do you have to reset the computer? If so how do you do that?
4.)What other tires do you use/recommend?
5.)At what intervals should I take my jag in for checkups? Its still under warranty and I want to keep it in top shape.
5.) Common problems to look out for.
6.) Diagrams/Procedures for general repair and maintenance.
7.) Spark plug recommendation and replacement procedures. Replace at what intervals?
8.) Aftermarket Intercoolers? I've heard of them, where to purchase?
9.) Can we get a posi rear? Will it interfere with the TCS?
10.) How do you adjust the lights? My motors still work but one is a little lower than the other.
11.) Post any other questions you have here. <
Old Aug 18, 2008 | 09:25 AM
MidGaSTR's Avatar
Default RE: Questions from a STR owner...
Number 11.) What how much HP can the 6-speed auto transmission handle? How do you change the tranny fluid? Recommended fluid? How many qts?
Thanks,
Gabe
Note* I'm getting a friend to fwd me the alldata for the o3's.
Old Aug 26, 2008 | 07:48 PM
03JagSTR's Avatar
Check out this site......
http://www.styperregistry.com/ServiceInfo.htm
Old Aug 26, 2008 | 07:59 PM
jag_genius's Avatar
thats a lot to ask for.. the parking brake caliper need s to be pushed in before installing new brakes.. there is a special tool for this.. not sure if there is a aftermarket tool.
supercharged cars need spark plug replacement every 96 k.
oil change every 5 k ..it takes 6.5 litrs of oil .
qdjust headlights.. open hood.. remove cover four plastic screws.. remove.. then at headlamps there are 2 outer white plastic adjusters the outside ones do up and down.. but they can brake when adjusted..
Old Aug 29, 2008 | 04:13 PM
jaguarevan's Avatar
Based on my years with my STR:
1) You can do the brakes yourself if you have done break jobs before and save a ton, the brembo calipars are actually pretty user friendly. Getting the right pads for an R is a little tricky, a lot of places have sent me the non-R pads promising me they areright, look for the two holes on top of the pad for the calipar pins, no holes, wrong pad. Jaguar does have a special tool for pushing the pistons but its not absolutely required. Trying out EBC Red Stuff ceramics next week actually, will let you know...
2) Not a whole lot out there, some go to Jaguar XP, some to Eurotek, Arden, etc... in the end not a whole lot, you will have to get creative. Those Exhaust kits area total rip off but the car sounds great with exhaust, pulls the mufflers off yourselfone day (just two bolts)when your bored and you will realize how great of sound can come out of this car with a good exhaust. I had a custom one welded by a friend, saved a ton. Left the H-pipe and cats as is though, didnt want to be too loud. Havent seen headers.
4) I have BF Goodrich G-Force T/A KDWs, love them, great tread pattern that really gives the car an aggressive look, gripgreatwhen drybut tires spin easily in the rain, and if there is even a little ice or snow dont plan on driving.
7) Beware the dealers on the spark plugs, huge overcharge, they are uridiums that normally dont cost more than $8 a piece, dealer will quote you hundreds to replace them and have told me that a "spark plug gasket" has to be replaced each time and this is why they upcharge so much....yet to do it....yet to confirm this gasket replacement, any help on this techs?
10) The headlights suck, period. You will have to get use to this. I have had them adjusted numerous times and even replaced and it still doesnt matter. Probably the number one issue on these cars.
11) The guys at Eurotek say they have put well over 500hp on that transmission and they have never broken one, they says its a beast, and you dont change the fluid, its all internal and not necessary, technically there is no real service you perform on this transmission. You can have jaguar check/update the computer software on it and thats about it, this helps if you start to notice issues.
All in all, I think its a great car, not a lot of them out there, and wouldnt give mine up.
Old Aug 29, 2008 | 04:16 PM
jaguarevan's Avatar
I just posted this is another thread but is relevanthere as well, thisis what Eurotek has offered via email:
We offer the Stage 1 kit which includes the ECU, R Specific intake and Pulley Upgrade, the Jag XP cone intake sounds cool and looks ok but you don’t make any real power.
Our Stage 1 kit is $1495 includes shipping. 35-40hp gain 30ftbs more torque
Stage2: Modified supercharger and throttle body on exchange only with new gaskets and EGR vale set up $1795, this will come with special pulley fitted on blower. Net gain 25 hp and 20ftbs more
Stage 3: Race exhaust No cats down pipes and all, adds 30hp $5395.00
Stage 4: Modification of the cylinder heads and valves this will gain 25hp price on exchange only $4995
Suspension shocks, springs, bump stops, strut hats and all hardware mounted for installation $3000
Old Aug 29, 2008 | 07:50 PM
MidGaSTR's Avatar
Eurotoys ltd. is in the works with Kenne Bell to fit the 2.1L supercharger on our cars. There quoting 100 - 200 hp increase instantly based on the efficient design of the s/c. I'll keep you guys up to date.
If anyone needs it I have a Jaguar Workshop Service Manual on disk that goes from 199x-2003 jaguar models.
Also, keep up the good job people! This has the potential to be a great fyi thread.
Old Aug 29, 2008 | 11:08 PM
badmojo's Avatar
The brake pads are a snap and the caliper pistons can be pushed back by hand. These are the pads that I replaced my factory pads with. They are quiet and virtually dust free!!
http://brakeperformance.com/site/bra...icle_type_id=1
clubairth1
30
Sep 3, 2025 04:38 PM
tbird6
Aug 13, 2024 07:50 PM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
DustysSon
Sep 13, 2015 04:17 AM
rachelstr
Sep 3, 2015 12:59 PM
