Radio Faulty
Old Sep 23, 2015 | 03:46 PM
puddled's Avatar
Default Radio Faulty
Trying to trace a battery drain on a 2000MY S-type.
I have been using an inline type current tester (the sort that replaces the fuse and measures he current being drawn by each circuit).
After pulling various fuses I got to fuse number 18 in the passenger compartment which supplies the permanent 12v feed to the radio, navigation and telephone.
My car only has the basic radio, no nav / phone / voice, but still seems to be pulling near 1.3amp via that fuse even when the ignition is off and the key removed.
I have completely disconnected the radio and the current reading instantly drops to 0.
Is it safe to assume that there is a fault in the radio causing the battery drain, as to me that seems rather high.
Old Sep 23, 2015 | 04:22 PM
JagV8's Avatar
It sure sounds like it.
Old Sep 24, 2015 | 12:47 PM
tbird6's Avatar
Yes. I think you did a very good job of troubleshooting.
Are you going to replace it with a stock or aftermarket unit?
Aftermarket will get you more for your money.
Old Sep 24, 2015 | 01:09 PM
puddled's Avatar
I am thinking of replacing with another stock unit, as I already have an iPod interface that will work.
oldjaglover
Dec 25, 2024 04:33 PM
Paora
Feb 4, 2021 12:36 AM
philwarner
Jan 31, 2016 09:36 AM
ziondio
Sep 28, 2015 11:24 AM
