rain sensor
Old Apr 14, 2011 | 07:58 AM
Jag Breeder's Avatar
Default rain sensor
Ok my 2001 s type rain sensor is not working I checked the fuse and its good its on the same circuit as the mirror is on and the rearview mirror dims and everything else perfect but my rain sensor is not working will is this common? Do you think I should change the sensor or the switch
Old Apr 14, 2011 | 09:35 AM
Gus's Avatar
Gus
I know nothing about the rain sensor but this oneline on the car should help http://www.gusglikas.com/images/Auto...x2022001en.pdf go to Fig 13.1 page 99 and you will see a Rain Sensing Module. I would check all the connectors from the fuse to the module. I hope this helps!
Old Apr 14, 2011 | 10:21 AM
You have checked the basics?
The switch is in the auto position isn't it? I've found that if the screen is not clean it can have an effect on the sensor operation.
Old Apr 14, 2011 | 04:23 PM
Yea the switch is in the auto position
Old Apr 15, 2011 | 08:21 PM
RizwanSharp's Avatar
Also the lever is one level up from the bottom? Just making sure because otherwise it does not work even if it is at auto...
Best Regards,
Rizwan
Old Apr 15, 2011 | 08:27 PM
PaulB's Avatar
I don't use that setting, I find it to erratic.
Old Apr 16, 2011 | 09:19 AM
Problem solved.
File Type: pdf
Old Apr 16, 2011 | 01:40 PM
Pushing_Tin's Avatar
I don't use this feature much, but I do find it work much better than the one I had in my Lexus and it was a 2006.
Poet
Feb 7, 2025 02:18 PM
picard
Oct 12, 2015 11:56 AM
SoCalJagS
Sep 27, 2015 09:20 AM
unicorn
Sep 23, 2015 02:59 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
