Reading ABS Codes with Scan XL Pro and ELM327
Old Jun 30, 2013 | 06:08 AM
ijSionG's Avatar
Default Reading ABS Codes with Scan XL Pro and ELM327
Hi guys !
After looking for hours how to read the abs codes for my 2002 S-TYPE without having to spend a lot of money (got the Traction control fault + abs light)
I got an ELM327 off Amazon and using ScanXL Pro with the Ford Diagnostics Enhancement Add-on, I was able to do it.
I had to say my car was a 2002 Ford Taurus 3.0L to benefit from enhancements and ta-da ! I was able to read the C**** codes
Thought this might be useful to some people so decided to share
Sion,
Old Jun 30, 2013 | 07:56 AM
clubairth1's Avatar
Community Influencer
Did you repair your car this way? I would be worried about using the wrong car to define the codes until we know they are the same.
Old Jun 30, 2013 | 09:54 AM
JagV8's Avatar
What did it all cost? A Mongoose JLR with SDD/IDS is probably cheaper!
I'm sure people already know AutoEnginuity has a jag-specific add-on, too, that does this and more but SDD/IDS is the official tool.
Old Nov 29, 2014 | 07:58 PM
Fresno2009's Avatar
Default P0327 and P1111 code for Jaguar S Type 2003
What does P0327 code mean?
What does P1111 mean?
PLEASE GIVE ME SOME INFORMATION ON THESE TWO CODES.
Old Nov 29, 2014 | 08:02 PM
Fresno2009's Avatar
I need to know what these two codes mean po327 and p1111.
Old Nov 29, 2014 | 08:04 PM
Fresno2009's Avatar
Default Reading code po327 & p1111
Please give me information on these two codes for jaquar s type 2003.
P0327 & p1111.
Old Nov 29, 2014 | 10:18 PM
joycesjag's Avatar
The p1111 is ok and normal.
The other, I am sorry I don't know off the top my head. My search button seems to be missing.
Old Nov 30, 2014 | 07:14 PM
Robinb's Avatar
Even Google can tell you P0327 is probably a knock sensor problem. Go have a look.
Old Nov 30, 2014 | 08:07 PM
tony1963's Avatar
If I had to guess, you have an ATE brand control module on your ABS unit. It is probably a bad module like a lot of Volvos that I have repaired (or had repaired).
The codes that you are chasing are likely ghost codes and you can't diagnose anything until you get that module ruled out as a problem. Send the module out for repair, then see what you have.
When you reinstall, drive the car a few feet and the light will go off if that was the problem.
FrickenJag
Jun 16, 2025 02:15 PM
Jpav27
Jul 31, 2022 06:43 AM
Adam Lueb
Sep 28, 2015 02:54 PM
OkieTim
Sep 8, 2015 04:48 PM
TexasCat
Sep 8, 2015 04:36 AM
