Rear parking sensors
Old Jan 13, 2009 | 02:08 AM
Stevil's Avatar
Default Rear parking sensors
I have an intermittent failure? 2001 V8. They work sporadically and I can't seem to figure out what's going on.
Old Jan 13, 2009 | 04:16 AM
lev's Avatar
lev
Default RE: Rear parking sensors
I guess obvious things to check are water and dirt on sensors. My sensors never work correctly when they are wet.
But ideally you should provide more information on the problem. What exactly is going on?
Old Jan 13, 2009 | 07:32 AM
harounq21's Avatar
you can replace them very cheap. I saw a set on ebay for like $35 new.
Old Jan 13, 2009 | 02:17 PM
Uptown Girl's Avatar
Mine go bonkers when it gets really cold out even if I make sure they are clear of snow & ice. When I back up they will do a constant beeeeeeep until I out her in drive. Luckily I haven't run anyone over by ignoring it. lol
Old Jan 13, 2009 | 03:34 PM
WinterJag's Avatar
Well, I have the same problem sometimes. They work fine until it gets really cold. I don't know how cold it is where you are but for me it happens usually because the exhaust fog creates that classic cloud behind the car when its really cold so this makes the sensors think that you are about to hit something. I also sometimes find that there is a very fine layer of frost over the sensors (so fine you can't really see it) and that is enough to mess with them. On any other day, they work just fine!
Old Jan 16, 2009 | 09:54 AM
jaguarevan's Avatar
Unfortunately quite a few s types have issues with water leaking into the trunk,this in turn can corrode the wiring in the back up sensors causing them to work intermittantly.
Old Jan 19, 2009 | 03:55 PM
Stevil's Avatar
The problem is totally random, wet or dry, hot or cold, clean or dirty, I think I might investigate the wiring as suggested.
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
innzane
Sep 2, 2015 10:08 AM
