refilling coolant after leak
Old Apr 28, 2010 | 06:34 PM
washuk's Avatar
Default refilling coolant after leak
Hi Guy's....I just repaired a broken coolant system in my 2003 Jaguar S-type 3.0 litre. It appears to me that the coolant that was lost is not being replaced by adding coolant to the plastic resevoir. When the engine temperature began to climb above it's normal mark I shut it off and decided it would be smart to get some help. Is there a procedure for adding coolant and also getting any air pockets out of the system??? Sure could use some good advice......Thanks...........Dan
Old Apr 30, 2010 | 10:56 AM
ndy4eva's Avatar
I noticed that too. When I check the coolant level in the morning, it's at pretty low level (just below min). When I check it after engine was running for a while, it's at max level.
Old Apr 30, 2010 | 11:23 AM
washuk's Avatar
I have not been able to find any info on bleeding the coolant system so far. I have done quite a bit of research on the internet and it seems that it is necessary to bleed the air out of the system but no one seems to know how to do it.
Old Apr 30, 2010 | 11:46 AM
MyBlackCat's Avatar
Top of page beside New Posts is Search...open and type in something like "bleed procedure or bleeding coolant system"
eventually you will get something, be persistant.
Bleed Value or Proceedure for 2000 S 3.0
This is one thread I found with my first search.
Good luck
aholbro1
Dec 29, 2024 06:46 PM
Wahooesprit
Dec 23, 2019 02:01 PM
willtoliv
Oct 2, 2015 12:18 PM
arskemp
Sep 21, 2015 02:19 PM
mhenz
Sep 14, 2015 07:47 PM
