Replacing standard radio in 2003 S-Type
Old Nov 9, 2023 | 04:03 PM
scrannel's Avatar
I mean... does it say "Alpine" on the front speakers? If so, you have a separate amp.
Old Nov 9, 2023 | 04:34 PM
Searay26's Avatar
No, it is the standard radio.
Old Nov 9, 2023 | 04:53 PM
Searay26's Avatar
Originally Posted by JagV8
Yes, that diagram shows the same as the one I was looking at, only an antenna amplifier.
Old Nov 10, 2023 | 11:13 AM
Bill400's Avatar
Originally Posted by Searay26
Installed a different radio yesterday...same result! Radio looks to be playing, everything worked, but just no sound. I also checked the fuses to the radio in the passenger foot area, that I found on a wiring diagram, and they were OK too. I guess I need to pull a door panel and look at a speaker....maybe test with another speaker. I'm stumped.
If you have the wiring diagram, you can test from the radio connector. Any handy test signal.
use an old earphone and connect to your iPhone audio jack. Play your iTunes while testing.
Even a 9v battery may be used to test speakers: connect jumper wires to the appropriate terminals for the speaker that you want to test and brush the other end of the jumper wires across the battery terminals.
As Clubairth1 explained, if speakers failed, repair may be accomplished with a simple solder connection at the terminal strip. However, if the braided copper crumbles when you touch it, replacement speakers may be in order. Good luck, let us know how you resolve the problem.
Old Nov 10, 2023 | 08:44 PM
Searay26's Avatar
Thanks, a friend of mine mentioned the 9 volt trick to me today. Wish I had known before the put the radio back in!
Tenagarlick
May 8, 2025 09:29 AM
GreatMaStEr
Mar 30, 2019 04:09 AM
hlotero
Nov 20, 2018 05:53 AM
ccm5385
16
Oct 28, 2011 06:40 AM
manderson10
Dec 29, 2008 07:26 AM
