rising temp needle....
Old Aug 19, 2007 | 08:28 AM
secondtonone317's Avatar
Default rising temp needle....
For the second time yesterday my temp needle shot all the way to the red. Its funny because I think it may be a problem with the needle/sensor. It went all the way up super fast thenall the way back down in a few seconds. Im not sure ifits the temp sensor of if its actually overheating. I added some orange coolant......any ideas, anyone experience the same thing?
Old Aug 19, 2007 | 09:29 AM
badmojo's Avatar
Default RE: rising temp needle....
Your thermostat may have stuck for a short time causing the car to get hot then opened and went back to normal. Wsa the car running for awhile or did it happen at startup?
Old Aug 19, 2007 | 05:32 PM
^ could be it went up all the way and then back down within a minute, is there a how to anywhere on changing the thermostat?
Old Aug 19, 2007 | 10:24 PM
badmojo's Avatar
Here's a generic one. If you can locate it, it is pretty easy to replace.
http://www.automedia.com/Keep/Your/E...cr20041201th/1
Hope this helps!
Old Aug 26, 2007 | 04:56 PM
Igloo112's Avatar
Been having the same problem. Just changed the Thermostat and it happened again. I'm having the sensor checked as we speak. (Or as I speak)...
Old Aug 30, 2007 | 01:02 PM
Igloo112's Avatar
Okay, It's not the sensor.
studentper
Feb 20, 2016 09:43 PM
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
tomkilner
Oct 9, 2015 07:10 AM
3lvis
Oct 1, 2015 01:56 PM
