Rough Idle no Codes
Old Jul 10, 2007 | 02:23 PM
ken@britishparts.com's Avatar
Default RE: Rough Idle no Codes
3.0 or 4.0?
Old Jul 10, 2007 | 03:01 PM
bigdreams05's Avatar
Hey bud, we don't use spark plug wires, we use coils!
Old Jul 10, 2007 | 05:49 PM
Envy337's Avatar
The earlier S-types usually dont flag a misfire code even though it is misfirinig.
Some scan tools have a feature you can see the misfire counter.
Old Jul 10, 2007 | 08:06 PM
jag_genius's Avatar
buy one and replace one coil at a time till you get the right one which makes the car idle fine...then throw away the bad one.
Old Jul 11, 2007 | 09:48 AM
The 3.0 models also have problems with the intake manifolds and gaskets. Do a little more research before just throwing parts at it.
Old Jul 11, 2007 | 06:15 PM
Envy337's Avatar
ORIGINAL: medic235
Sam if your gonna chase a bad coil around, I would go ahead and invest the few dollars it would take to change out both intake gaskets. To be completly honest with you I would change all 6 coils. With 90,000 miles I would say that once you change one it won't be long before you'll be changing another, then another,ect,ect, ect.
Agree 100%.
I worked on a S-Type last week that had a bad coil. Extended warranty only covered the bad coil.
Car came back yesterday with a different coil that went bad.
Old Jul 11, 2007 | 08:22 PM
jag_genius's Avatar
gotta Love those coils.. lol
Old Jul 12, 2007 | 01:59 AM
kiloslanga's Avatar
damn coils.
Old Aug 4, 2008 | 09:43 PM
nunyadamnbiz's Avatar
I hate these damn coils...is there no way to test with a multimeter or anything...or just freakin remove and try each one....wow...what a pain in the a$$
Old Aug 5, 2008 | 12:08 PM
bleachii's Avatar
So is this a doable job at home for the ordinary person or is it difficult? Are there any repair manuals for the S-Type. I didn't find anything on a quick Google search.
Old Aug 12, 2008 | 11:28 PM
T.C.'s Avatar
its not a hard job. just get a 7mm wrench or socket and remove the two plastic covers from the tops of the valve covers and voila theres your coils. you can get coils from any major autoparts store just have them look up a 2000-2002 Lincoln LS V8. Same exact engine just different intakes. I think they were like 48 dollars each last time i checked.
As previously mentioned a proper scan tool (matco, snapon, Genesis, ect) will have a misfire counter per cylinder and it will tell you where to start as far as coil replacement. I have replaced one thusfar and i think im gonna have to do another soon. intermittently has bad idle.
Good luck.
Bcrary3
Feb 21, 2023 04:29 AM
Mac Allan
Oct 27, 2015 04:49 AM
Papelione
Sep 21, 2015 06:13 PM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
