rpm match
Old May 16, 2011 | 08:10 AM
roger00s's Avatar
Default rpm match
on my 2000 4.0 stype, when i shift to neutral at 60 miles per hour the rpms will increase from 1800 rpms to a little over 2000 rpms. I was wondering if this is normal
Old May 16, 2011 | 10:16 AM
Mikey's Avatar
No, it's not normal for someone to shift to neutral at 60mph, or any speed for that matter.
Old May 16, 2011 | 12:06 PM
roger00s's Avatar
that was not the question
Old May 16, 2011 | 02:19 PM
plums's Avatar
Only for the sake of completeness:
... except when performing a proper double declutch.
Admitttedly, it is completely irrelevant when discussing automatics.
Old May 16, 2011 | 02:25 PM
phd12volt's Avatar
considering the car monitors the speed and idle, it would seem normal to me, so that when you do shift back into drive the RPMS are matching the speed it could be at when in drive??
i know my DSG in my GTI acts funky sometimes, but really the computer knows where it should be at all times.
Just a guess though
Old May 16, 2011 | 04:27 PM
Mikey's Avatar
Admittedly so, but going in and out of drive while the car is in motion is not normal either. Why do it?
Old May 17, 2011 | 07:06 AM
roger00s's Avatar
You all did a nice job of not answering the question
Old May 17, 2011 | 08:30 AM
phd12volt's Avatar
Just a guess though
since you overlooked my response earlier
Old May 17, 2011 | 09:25 AM
Mikey's Avatar
My guess is that if there was someone else here that had done this, he/she would have posted the results.
Old May 17, 2011 | 10:39 AM
SchultzLD's Avatar
hummm...
considering the car monitors the speed and idle, it would seem normal to me, so that when you do shift back into drive the RPMS are matching the speed it could be at when in drive...
+1 Sounds like an answere to me
What an ***!
HA HA HA
Here's your sign... lol
Old May 17, 2011 | 11:41 AM
JagV8's Avatar
I don't have a 4.0 but wouldn't try that if I had.
BTW, definitely don't try it in Cruise.
Old May 17, 2011 | 12:41 PM
Gold_04_X-Type's Avatar
When you shift the car into Nuetral, at any speed, you are essentially disconnecting the engine from the drivetrain, the engine no longer has the load of the moving vehicle bogging it down. The energy that was just before being used to propel the vehicle forward will now cause a rise in engine speed because the load is no longer there.
Old May 17, 2011 | 12:54 PM
Mikey's Avatar
This would be true only if the driver kept his foot on the gas pedal while shifting to neutral. Surely the OP didn't, ummmm OK never mind.
Old May 17, 2011 | 12:56 PM
Yes it's all conjecture, cause nobody else is going to try it!!!
ArtyH
Oct 2, 2015 11:39 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 01:59 AM
dansxj6
Sep 28, 2015 08:02 AM
