S-Type 2000 Auto Trans. Question
Old Nov 23, 2011 | 12:16 PM
GusCavalieri's Avatar
Default S-Type 2000 Auto Trans. Question
Greetings from sunny Florida and Happy Thanksgiving to all; my question is very simple I think, my s-type doesn't have the oil dipstick for the transmission and jaguar claims that the transmission is sealed and a refill is only required in case of a leak... My other car is a E46 manual and BMW claims the same, to me is a silly statement since I replace my transmission oil every 35k without problems. There is any way to check the transmission oil in my jag and drain it or replace it?, I don't feel comfortable with the fact that my car is 75K running with the same oil...
I really appreciate your comments and thanks in advance...
Old Nov 23, 2011 | 12:29 PM
JagV8's Avatar
Take a look in the FAQs
You may need a few more posts to see the detailed pics.
Old Nov 23, 2011 | 01:27 PM
It can be done, as John says you will need ten posts before you can see attachements etc.
You're half way there.
Old Nov 23, 2011 | 02:35 PM
Jochem00's Avatar
You do not even need to see the attachments to find this out with a proper research
Old Nov 23, 2011 | 03:08 PM
chucky60's Avatar
Default Mercon V
It's a Ford. Drain from plug. Remove cover and filter. Install new filter and replace cover with new filter . Torque bolts. Put drain plug back in and the trans has a fill plug on upper right back side. It should take what ever drained out which might be about five and a half quarts . You can check for proper fill if you can jack the whole car up level and run it till the fluid is warmed up and losen the drain plug until a little drip of fluid is only draining out. Mercon V is the fluid. And it is sold everywhere "Cheap" Or have a foreign car garage do it for you and tell them to buy the stuff at $1.47 a quart from Napa Auto Suply. It is not good for life. Unless you want it to have a short one. Make sure the fluid is not dark or you may be wasting your time.
Wolfy
May 28, 2024 08:06 AM
Bcrary3
Sep 12, 2021 05:41 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
pocketrocket
Sep 3, 2015 07:44 PM
pnwrs2000
Sep 3, 2015 11:55 AM
