S-Type 2003 3.0 Big Question RESOLVED
I have problem with my jag. He dont accelerate well, a cant diagnose via WDS or IDS bc nobody got this device in my area. Here is an Video, my english isnt perfect , so write to me simply as u can, cheers
https://files.fm/u/taem8eqv
Welcome to the forum trycons,
You probably don't need anything as sophisticated as WDS / IDS can you get a simple OBD reader and check for codes.
Make sure the battery is fully charged and in good condition before doing much more.
Do you have a P1111 code?
The car sounds like a tractor in the video. Does the check engine light illuminate when you switch on the ignition to pos 1?
The DSC not available warning is often a sign of a poor battery, do you get any other warnings?
Quite often misfires don't set a DTC (Diagnostic Trouble Code). The engine may have oil leaking into the spark plug wells causing the coil units to short creating the misfires.
May also be running lean due to the collapsed breather hose under the lower inlet manifold.
@Norri
DSC warning is becouse steering angle sensor fault. Battery is replaced to new one. I got cruise control warning too, but no DTC's on OBD.
@NBCat
Hello, spark plugs are changes for new, same as new gaskets , OEM Jaguar for this model, "May also be running lean due to the collapsed breather hose under the lower inlet manifold" - where can i find this hose and how it looks ?
@NBCat
@Norri
@NBCat
https://www.sngbarratt.com/uk/#!/Eng...a-6a9ad3966d66
If you are removing the intake manifold, the spark plugs and valve cover gaskets on the right bank should be replaced as a matter of course. Some owners have also replaced the coil-packs on this bank at the same time, as access with the manifold in place becomes problematical and costly.
You should probably add the IMT orings to the list "while you are in there" C2S40669
The cam cover gaskets are XR851930 Right and C2S34512 Left + 2 spark plug seals XR847907
P1000 indicates a fault if you don't have a code you will soon or should.
How many kilometres are on the vehicle?
Spark plugs - C2S46895 X 6
Coil units are VIN-specific and should be replaced with spark plugs, especially on Bank 1 due to position of the upper inlet manifold.
Upper and lower inlet manifold gaskets are VIN-specific and six are required of each.
