S Type battery drain
Old Jun 5, 2012 | 11:34 AM
Quinny's Avatar
Default S Type battery drain
I am having problems with the battery going flat overnight. The battery is new.the same time have started getting random alarms on the dash ie. hand brake fault, apply foot brake and hand brake to mention 2. Also the windscreen wipers do not return to the bottom of the screen when turned off or in rest position, don't know if this is related.
Has anybody had a similar problem and how was it put right ?
Thanks.
Old Jun 5, 2012 | 11:46 AM
JagV8's Avatar
I have read that the wiper problem can cause the battery to go flat so consider fixing the wipers and see.
Old Jun 5, 2012 | 10:21 PM
Blue Lion's Avatar
I haven't had that problem but maybe a battery tender would help?
Old Jun 6, 2012 | 01:35 AM
abonano's Avatar
Test each indiviual battery cell - odds are you could have 1 or 2 "flat" or bad cells throwing the battery off - what you describe sounds like a failing battery - also, check the manufacturer date code on the battery as well... Be sure to post your vehicle information in your signature line and if you haven't done so already - please post a brief intro in the new member section.
Old Jun 7, 2012 | 07:37 AM
Quinny's Avatar
Booked car in for a new wiper motor. Jag Centre agreed that this is most likely cause of battery drain. Going in for repair eary next week. Will keep you posted. Thanks to all for your help so far.
Old Jun 7, 2012 | 10:39 AM
Mikey's Avatar
To determine whether the battery is also faulty, disconnect the negative cable and see if it self-discharges in the same period of time.
Old Jun 8, 2012 | 07:15 AM
Staatsof's Avatar
Default Perhaps this will help?
I hope my problem is fixed now.
Have a look.
https://www.jaguarforums.com/forum/s...x-today-61377/
My situation was different sounding than yours.
Old Jun 10, 2012 | 11:15 AM
Quinny's Avatar
Latest news. Took car into garage, they found a faulty wire to the wipe motor and replaced it. Wipers work fine now. They said that it would have caused the battery drain also. Up to now all is ok.
Old Jun 13, 2012 | 11:34 PM
Quinny's Avatar
Still having problem with battery drain. Faulty wire causing wipers to be faulty not the cause of battery drain. If I take the negative wire off battery over night, the battery does not drain.
Anybody any idea what it is ?
Old Jun 14, 2012 | 02:06 AM
JagV8's Avatar
Very long existing threads here have all the gory details so just work through them. Can be very painful but the details are there, with pointer to PDFs etc.
Old Aug 20, 2013 | 08:47 AM
gr1's Avatar
gr1
Default s type 2004 diesel
did you find the fault I also think I have a drain as iv had the battery tested its ok. without any warning in two week ago my battery was flat jump start from breakdown van ran ok till 2 week later same thing.can any1 help
Old Aug 20, 2013 | 11:43 AM
JagV8's Avatar
See my reply above. It's going to require you to put in the work.
Old Aug 21, 2013 | 04:18 AM
Quinny's Avatar
Found fault as a wire from the wiper motor was going down to earth.
Old Aug 22, 2013 | 01:59 AM
gr1's Avatar
gr1
iv had the same fault on my 2004 diesel s type my battery and alternator has been tested told both ok .iv tested with a amp meter for a drain and found a drain of 0.9amp iv no idea if this is normal. my car will run ok for about 2 week then with no warning one day flat with no warning ie slow startin so my question is...... is there a commom fault ie wiper motor/alarm...... that can cause this 0.9amp drain
Old Aug 22, 2013 | 02:04 AM
gr1's Avatar
gr1
will a diagnostic at jaguar show where the battery drain is from id normally take it straight to jaguar to find the fault but at 150 pounds an hour and iv been told this could take a long time to find the drain im worried I could be paying 1200 pounds a day to find the drain. so if anyone has had a drain fixed id be thanfull for your help
Old Aug 22, 2013 | 02:56 AM
jimbov8's Avatar
Hi,
The chart attached will tell you what you should be getting when the car is "asleep".
The usual suspects,
When you remove the key from the ignition, has the little flap closed?.
Confirm all courtesy lights go off.
If you have the auto function for lights, switch them off.
Switch off the steering column adjustment.
Switch off the auto function on wipers if fitted.
Confirm when locked, no warning on message centre.
These few things should help you track it down then all you have to do is rectify it.
Hope this helps,
Old Aug 22, 2013 | 03:47 AM
JagV8's Avatar
There are plenty of very detailed threads on here with all the suspects, tests & fixes. You're looking for a drain after 40mins of say 50mA. Just go reading.
The jag diags generally can't find this stuff because to operate they draw amps.
You need old fashioned electrical tests not electronics tests.
Old Aug 22, 2013 | 06:03 AM
gr1's Avatar
gr1
thanks to ill work on your tips thank
Old Sep 7, 2013 | 03:54 PM
drun's Avatar
I had this same issue and my battery drain problem was a faulty ignition switch, (the back half can be replaced without removing the key portion). These are a result of heavy keychains that leave the switch partially on and it burns the contacts.
There was a thread on here quite a while ago with a reply from a dealership mechanic stating this was so frequently the cause that they automatically changed out the rear of the ignition switch first.
Old Sep 7, 2013 | 06:32 PM
cloud hands's Avatar
Thats some good info there, Peace....
The ingnition switch on my car is buggerd and therefor to stop the battery drain issue the previous owner installed a ford solenoid next to the battery with and activation switch under the steering wheel. This effectively cuts off the whole car from any drain source. It has no memories for the display settings and every day is a new day for my car.
