S-type - engine light on and off intermittently
Old Jul 27, 2012 | 12:58 PM
Izabelle's Avatar
Originally Posted by JagV8
Izabelle, I agree with the others that some extra sealing sounds to be needed. (It's supposed to be sealed but sometimes it fails, whether heat age or what I don't know.)
You can look the details of the codes up in the codes PDF from the FAQs (get the one for your car era). (Briefly, P0300, P0301 & P0305 are misfires, P1316 is another misfire-related and P1582 indicates specially stored data you can normally ignore.)
You should be able to use a car wash (though I wouldn't LOL) but they do tend to be rather aggressive and find any weaknesses as well as being rough on paint etc.
Dear JagV8 - thanks so much for the great advice.
Old Jul 27, 2012 | 01:00 PM
Izabelle's Avatar
Originally Posted by Norri
I'd guess an easy couple of hours, with a coffee break in the middle waiting for the silicone to dry.
As Gus says, no need to take the bonnet (hood) off.
Dear Norri - thanks very much for your help with this issue.
Old Jul 27, 2012 | 01:02 PM
Izabelle's Avatar
Originally Posted by Gus
Looking at the instructions the hood does not need to be removed. The problem you may run into is the removal of the wiper blades arms they can at times get stuck to the armature. Other than that it appears to be a relatively simple job.
Dear Gus - thanks very much for your help with this.
Old Jul 27, 2012 | 09:03 PM
Gus's Avatar
Gus
Diverting the water is only part of the problem. I would suggest cleaning the connectors on the TB at the same time.
Old Aug 8, 2012 | 01:39 PM
2000JagLvr's Avatar
Default Bad info
No it can't. There are NO plug wires on these cars.
Izabelle - Don't try the above. Just get the codes.
you are correct JagV8. I forgot what engine we're talking about. I've had too many older cars with the same problem.
Old Aug 8, 2012 | 02:18 PM
JagV8's Avatar
Don't worry, I don't think it actually caused any trouble
stanjag
Dec 29, 2024 08:26 PM
kurtomatic
Feb 12, 2024 06:58 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
big d
Sep 3, 2015 07:37 PM
dpappyp
Aug 27, 2015 06:31 AM
