S-type front seat backrests wobble sideways
Old Oct 9, 2021 | 08:01 AM
TheNovice's Avatar
Default S-type front seat backrests wobble sideways
Hi,
was considering buying an old s-type today. When I test drove it I felt the backrest moving sideways. Read som threads about front seats squeeking and wobbling but that didn’t fit into this problem.
after the test drive I took a firm grip on the seat and pushed it sideways, and it moved quite a lot down at the hinges, the plastic covers almost broke ( felt like they were about to break).
Anyone knowing the reason for this problem? Easy to fix?
best regards
Old Oct 9, 2021 | 08:56 AM
kr98664's Avatar
What year is the car? On my '02, one of the hinges failed, where the seatback reclines relative to the base. It's not just a simple hinge, but more of a planetary gear arrangement for the power recline adjustment. A plastic bushing failed and allowed the gear teeth to skip. If you leaned back in the seat, it would flop back a couple of inches. Can't say there was really any side-to-side movement, just fore and aft.
Sad details of my repair attempt here:
https://www.jaguarforums.com/forum/s...solved-239642/
To summarize Proust, I don't believe this geared hinge mechanism was designed to be repaired. Jaguar's official fix was to replace the entire seat assembly. I had a HECK of a time trying to repair it, and the seat fought back every step of the way. I was about ready to just weld it together in a fixed position when I somehow managed to get all the little pieces assembled. If you encounter a seat with a bad recline hinge mechanism, I would recommend replacing the seat with a serviceable used unit versus trying a repair.
This was on an early model. I do not know about 2003+ models.
Old Oct 9, 2021 | 09:40 AM
TheNovice's Avatar
Default Yep it’s a 2002 years model
The play back and forth was not so noticeable, it was much more disturbing sideway movement. While driving I was tossed left and right when turning (slightly exaggerated, but clearly noticeable and disturbing) At first I thought it was the side pads that had broken. But when I stopped intested the seat backrest and it was very sloppy sideways.
S-type Enthusiast
Jul 22, 2021 11:22 PM
pablomonk
Mar 1, 2018 05:17 AM
bendebusk
Jan 22, 2018 09:45 AM
WhiteKitty
Aug 25, 2013 07:47 AM
rspencer1212
35
Jan 20, 2011 05:38 PM
