S-type mis-fire codes
Old Mar 20, 2019 | 12:46 AM
hocojimjag's Avatar
Default S-type mis-fire codes
My 2005 S-type V-8 with about 90K miles occasionally mis-fires on start-up, especially when warm. Codes for 1 3 5 7. Thoughts, pls?
Old Mar 20, 2019 | 09:18 AM
Don B's Avatar
Hi hocojimjag,
All of your misfires are in Bank 1, the right bank of cylinders as viewed from the driver's seat. A couple of possibilities come to mind:
1. Leaking spark plug tube seals on the Bank 1 camshaft cover, allowing oil to spill into the spark plug tubes, which interrupts the spark plug ground path through the cylinder head and causes misfires. You can check for this by pulling a couple of the ignition coils and looking down into the spark plug tubes for oil. The solution is to replace the cam cover gasket and spark plug tube seals.
2. An air leak at the PCV valve/vent or its associated plumbing can cause lean running and misfires in only Bank 1, but you will usually also have a lean code for Bank 1 (P0171). The PCV vent is the flat, black circular component mounted near the front end of the Bank 1 cam cover. Often, you can hear the sound of air hissing near the vent, and by (carefully) manipulating the vent and the plastic hose attached to it you may hear a change in the hissing sound, confirming the leak(s).
Cheers,
Don
khsmith55
Feb 7, 2018 07:36 PM
Countriboi03
Aug 3, 2013 04:54 PM
Languid
Aug 26, 2012 04:11 PM
hatajay
Nov 30, 2009 03:46 AM
F8ABE
Feb 6, 2009 05:44 PM
