S type r burning oil
Old Nov 2, 2009 | 05:49 PM
MARK's Avatar
Default S type r burning oil
I have an 03 STR and I have an issue with oil burning, i have no leaks underneath..bone dry---I currently use Mobil 1 10w 40 (synthetic) and the engine seems to burn a fair amount of oil...2-4 quarts between oil changes. I know its normal but the last time I went 4,000 miles and 4 quarts burned away..I know the say thats normal for superchargerged engines but should I use a different viscosity to offset extreme oil consumption---she has abt 100,000 on the clock--Is there something else I should be looking at.
Old Nov 2, 2009 | 10:44 PM
tomciob's Avatar
I have an 03 str with 78k atm. Run 5w-30 synthetic of the pennzoil platinum verity at the moment and burn about 1/2q between 5k change intervals. I had burning issue develop almost over night and it turned out to be valve caver gaskets and spark plug seals. My spark plugs were soaking in oil especially on the driver side of engine, surprisingly the coils did not short or cause any miss fires.
Old Nov 3, 2009 | 01:53 AM
JagV8's Avatar
1. It's NOT normal to burn so much.
2. You're using the wrong oil. It should be 5w30 and semi-synth.
I do not think that will fully explain your loss, though.
You should hope you have a leak because if you are burning so much then it's not good news. So far, mine's not burning any.
Old Nov 3, 2009 | 08:37 AM
tbird6's Avatar
I have a 2005 STR with 46K miles. I use about 1/2 to 1 qt every 7500 mi. Just can't go the full 10K oil change like Jaguar recommends!!
Old Nov 3, 2009 | 11:30 AM
damienedwards's Avatar
Have a 2003 STR with 80k miles on the clock and uses about 2 litres of Castrol magnatec 5w-30 between 10k service...........not sure what you mean by Quarts (quarter of a gallon??) British huh!! lol..... but thought this was a bit much on the usage front??
Have noticed a tiny puff of blue smoke on start up though just hoping its not the Valve stem seals!!! no smoke on run or full boost though
Old Nov 3, 2009 | 12:46 PM
They used to have quarts in the UK when Noah and I were boys.
Old Nov 3, 2009 | 02:18 PM
JagV8's Avatar
quart = 2 pints, surely
pint = 16 fluid ounces (USA), 20 fluid ounces (UK) - I think!
(gallon is 8 pints, in both, but the pints are bigger in UK)
Old Nov 3, 2009 | 02:46 PM
metalmarty's Avatar
I have an 03 STR with 30k miles. I do know that I have to add a quart at around 5k, but I am not sure exactly how much is lost. I'll be changing the oil tomorrow at 7500, at which time I'll take a more precise measurement.
Old Nov 3, 2009 | 02:54 PM
Yes they are.
Old Nov 3, 2009 | 05:54 PM
badmojo's Avatar
Same here. As I posted in a previous thread if get on it hard it will smoke a little the next time I start it up but only if it sits for several hours. It's a whitish gray smoke. A little over 70000 on mine? My Mechanic says it may be unburned fuel but Oil level does go down between changes, and I do changes about every 4000 mi.
Old Nov 5, 2009 | 07:04 AM
well i think i agree with the pints being bigger in the UK..............but having been on a recent trip to Vegas and checking out some of the women, there are definately some assets that are bigger in the US
Old Nov 8, 2009 | 09:12 AM
Marc's Avatar
Leave 10-40 motor oil alone. It used to be way over rated. Many places don't even sell it anymore. The viscosity spread is too great, and it is just a cheap consumer oil. Million dollar industrial engines use 15W-40 diesel grade. There's a reason for that. The additive package is much more stable and less likely to burn off. The cheapest 15-40 out there will in many cases out perform many high end syn blends and so called 100% syn. Diesels aren't cheap and need the best oils. The oil makers are liable for oil related damages too. This is what I use in my mowers, edgers, tractor, wifes Cougar, custom built 406 Chevy with 500 hp, twin cam Harley, and the Jag. Bought the Cougar 3 years ago. It used a quart a week. Started using the 15-40 in it and have not had to add oil since. Change the oil once a year if it needs it or not usually at the onset of winter time. Have not had an oil related failure using diesel motor oil in gasoline engines for 20 years now. I have used, Rotella, Mobil unsynthetic, and mostly Royal Purple now since the last 5 years. One oil for everything I own. Saving a ton of money. It's guaranteed to mix with anybodys oil in writing and they mean it. Read the API label circle on the containers. CC,CD, CF etc is for compression engines. SE, SF, SG etc means for spark engines. You see a C series and an S series in that API circle, it means either or. Don't let anybody tell you different.
Older higher mileage engines with wear, need higher film strength to help cool, clean, seal, & lubricate properly.
Old Nov 10, 2009 | 04:24 PM
metalmarty's Avatar
Here is my update.
I previously changed the oil about 6 months ago. I used 7qt mobil 1 5w30 and a fram toughgard filter.
5000 miles later, I added 1qt of the same oil.
At ~7300 miles I did another change, and drained slightly over 5qt of oil.
My '03 STR burned 3qt of full synthetic oil in 7300 miles. The car now has ~30k miles on it.
Old Nov 11, 2009 | 04:55 AM
JagV8's Avatar
mm - wow, that's a lot of oil! Do you do anything to it that might be termed abuse? Er, not wanting to annoy you just asking cos otherwise you need to find where it's going. It may not be being burned
Mine's an 04 STR 70k miles and touch wood uses no oil at all so far as I can tell.
Old Nov 11, 2009 | 08:47 AM
Enthusiast's Avatar
I lose a lot of oil with no smoke or oil on the plugs. No leaks. Normal usage?
Old Nov 25, 2009 | 04:53 PM
MARK's Avatar
Marc,
in terms 0f the 15w40 oil you spoke of which do you recommend and where can I find it my 2003 str has 100k on it and i need a very good oil, who do you recommend and where can i get it.
Old Nov 25, 2009 | 05:01 PM
JagV8's Avatar
Enthusiast - how much do yo umean by "a lot"?
Old Nov 26, 2009 | 09:39 AM
Enthusiast's Avatar
I put a pint every two months.....
Old Nov 26, 2009 | 10:10 AM
JagV8's Avatar
ahem. what sort of mileage (km-age?) do you do in that time?
Old Feb 18, 2011 | 06:18 AM
jetlag700's Avatar
Hi, I was researching oils for my 1988 Jaguar XJS, the compression is good, it has 135,000 kilometers, and it never smoked til NOW~!~! The engine was timed properly this time, new plugs, new wires, cap and rotor, mechanical advanced was seized and repaired, THEN the mechanics put in SEMI-SYNTHETIC OIL, now it has blue mixed with the mostly whitish grey "smoke",(it is really cold here right now, -30 Celsius). I was told that the semi synthetic oil has smaller molecules and it does not have "swelling agents" in the oil for the rubber seals.
Then my friend said he uses Rotella oil because of all the additives. Now I don't know what the hell to do.
Will getting rid of the semi-synthetic and going back to conventional oil get rid of the "smoke'?
