s-type r headlight assembly
Old Jun 28, 2010 | 10:53 AM
Staatsof's Avatar
Default Can one of the Techs clarify something?
I've read this and other threads on this HID head light assembly repair. I'm still not clear if this is a full repair so that the headlamps will properly self level and thus pass any state inspections or if this is a temporary fix so that you're going to have to get new units eventually?
Thanks.
Bob S.
Old Jun 28, 2010 | 04:34 PM
DTB's Avatar
DTB
This fixes a common problem when the manual adjustment breaks and the headlights point down. If the auto leveling function still works but the manual adjustment knob is broken, you will see the headlights move up and down when you turn them on, but they will always point downward.
Here is how the system works: You have to manually align your headlights to point straight ahead. The auto leveling will adjust the headlights up or down to keep them pointing straight ahead. So for example if you put something heavy in the trunk and the rear end sags, the auto leveling will adjust the headlights down so they aren't pointing at the sky. The plastic knob for the manual adjustment tends to break causing the headlight to flop forward and point down. Inserting a screw into the housing pushes the headlight back up to where it should be. The auto leveling adjusts up and down from that point.
I don't see why this would cause problems with an inspection or how they would even know you've done anything.
Old Jun 28, 2010 | 05:13 PM
JagV8's Avatar
Hey... good explanation!
Old Jun 28, 2010 | 09:00 PM
Staatsof's Avatar
That's what I wanted clarified. This fix doesn't lock them in a static adjustment then. It just fixes the broken base adjustment resting spot.
Thank you.
Bob S.
Old Jun 29, 2010 | 09:18 AM
Brutal's Avatar
Originally Posted by staatsof
that's what i wanted clarified. This fix doesn't lock them in a static adjustment then. It just fixes the broken base adjustment resting spot.
Thank you.
Bob s.
ant to further clarify, the screw is now your horizontal aimer. Just screw it in more to raise or out to lower. Turn on your lights at night and pull up about 8-10' from a wall or the garage and set them. I also do this mod to provide support before they break too!!!
Old Oct 22, 2011 | 02:30 PM
EdBowes's Avatar
Hi Eric,
Thanks for the excellent post! I'm having the exact same issue for the 2nd time with my '03 S-Type and I'm not paying $2,500 to have them fixed this go around!
If you happen to have any pics of your work, that would be a Godsend. Please post or e-mail (mine is ed_bowes@yahoo.com).
Thanks for the excellent work.
Cheers!
Ed.
ed_bowes@yahoo.com
Old Nov 1, 2011 | 06:48 PM
EdBowes's Avatar
I performed the quick drill and boly fix for my headlights. Worked great! The dealer wanted $3,200 and I did it for $3.47. Wow!
Many thanks.
Cheers!
Ed.
Old Mar 25, 2014 | 10:06 PM
  #28
GearHeadATL's Avatar
Originally Posted by Brutal
YOU CAN FIX THEM WITH 2 SELF TAPPING SCREWS, AND WHY WOULD NT YOU TRUST THE DIAG, THEY BREAK ALL THE TIME AND IT TAKES ME A WHOLE 30 SECONDS TO DIAG BROKEN HEADLIGHTS. PULL THE RADIATOR COVER, AND GRAB THE HIGH BEAM ELECTRICAL CONNECTOR, IF THE ASSEMBLY FLOPS INSIDE ITS BROKEN, IF FIRM ITS NOT. THE ADJUSTER TOP CENTER INSIDE THE LIGHT BREAKS ALL THEY FLOP FORWARD, IF YOU PULL BACK THE RUBBER AND SCREW 2 SCREWS IN 1 EACH ASSEMBLY. IT SCREWS IN,HITS THE FARWARD CUP OF THE ADJUSTER AND YOU CAN NOW SET THE HEIGHT BY SCREWING IN AND OUT. THE COOL THING IS THEY STILL AUTO LEVEL WHEN STARTED AND YOU JUST SAVED OVER A GRAND. YOU CAN PAYPAL ME A NICE $50 TIP
BBRUTON2001@YAHOO.COM
Hi Brutal... Regarding your elegant "Brutal Screw" fix, once the screw locks the headlight assembly rearward, you said it still levels (sweeps up/down) during startup. How is that possible if the mechanism is pinned back? Maybe I just don't understand the mechanics of the motorized system...
Both of my 2003 S-Type headlight motors run, both lights wiggle up/down, then they both droop. The left headlight is aimed a little higher because I was able to adjust the leveler screw a little. Neither headlight aims high enough to see at night.
Thank you for your contributions! You rock!
Old Mar 26, 2014 | 02:52 AM
JagV8's Avatar
The screw supports another part. Try it and see.
Old Dec 1, 2014 | 05:32 PM
  #30
juamed58's Avatar
Default Dropping Headlamps
Originally Posted by billings
i am a new owner and my headlight assemblieswent south, and both lights are in the down position. been told i need two new assemblies. found some on-line for around 400 a piece, but saw something about having to remove the bumper.
anyone have some info on how to replace the entire assemblies? hard?easy? got a quote for $2,700, which seems totally from outerspace.
go to this Link and you will learn how fix the dropping headlamps
Old Jan 28, 2015 | 08:40 AM
  #31
StypeRowner's Avatar
Default Worked for me !!!!!!!
I e-mailed the manufacturer years ago and berated their lousy engineering and lack of warranty coverage and, as you probably already expected, got no reply.
Thank you Forum for a great fix !!!!!!
Regards,
Old Aug 27, 2021 | 06:34 AM
  #32
JMBH's Avatar
And this was in 2009. And just want you to know that it is still being read and proving usefull to today on mine in 2021!
Old Oct 6, 2021 | 04:45 PM
  #33
simeon40's Avatar
That's why I always prefer the forums than Facebook groups.
GGabriel
Nov 22, 2018 03:53 AM
Jpav27
Sep 26, 2015 03:33 PM
European_Auto11558
Sep 25, 2015 08:05 PM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
