s-type r headlight assembly
I've read this and other threads on this HID head light assembly repair. I'm still not clear if this is a full repair so that the headlamps will properly self level and thus pass any state inspections or if this is a temporary fix so that you're going to have to get new units eventually?
Thanks.
Bob S.
Thanks.
Bob S.
This fixes a common problem when the manual adjustment breaks and the headlights point down. If the auto leveling function still works but the manual adjustment knob is broken, you will see the headlights move up and down when you turn them on, but they will always point downward.
Here is how the system works: You have to manually align your headlights to point straight ahead. The auto leveling will adjust the headlights up or down to keep them pointing straight ahead. So for example if you put something heavy in the trunk and the rear end sags, the auto leveling will adjust the headlights down so they aren't pointing at the sky. The plastic knob for the manual adjustment tends to break causing the headlight to flop forward and point down. Inserting a screw into the housing pushes the headlight back up to where it should be. The auto leveling adjusts up and down from that point.
I don't see why this would cause problems with an inspection or how they would even know you've done anything.
ant to further clarify, the screw is now your horizontal aimer. Just screw it in more to raise or out to lower. Turn on your lights at night and pull up about 8-10' from a wall or the garage and set them. I also do this mod to provide support before they break too!!!
Hi Eric,
Thanks for the excellent post! I'm having the exact same issue for the 2nd time with my '03 S-Type and I'm not paying $2,500 to have them fixed this go around!
If you happen to have any pics of your work, that would be a Godsend. Please post or e-mail (mine is ed_bowes@yahoo.com).
Thanks for the excellent work.
Cheers!
Ed.
ed_bowes@yahoo.com
Cheers!
Ed.
ed_bowes@yahoo.com
YOU CAN FIX THEM WITH 2 SELF TAPPING SCREWS, AND WHY WOULD NT YOU TRUST THE DIAG, THEY BREAK ALL THE TIME AND IT TAKES ME A WHOLE 30 SECONDS TO DIAG BROKEN HEADLIGHTS. PULL THE RADIATOR COVER, AND GRAB THE HIGH BEAM ELECTRICAL CONNECTOR, IF THE ASSEMBLY FLOPS INSIDE ITS BROKEN, IF FIRM ITS NOT. THE ADJUSTER TOP CENTER INSIDE THE LIGHT BREAKS ALL THEY FLOP FORWARD, IF YOU PULL BACK THE RUBBER AND SCREW 2 SCREWS IN 1 EACH ASSEMBLY. IT SCREWS IN,HITS THE FARWARD CUP OF THE ADJUSTER AND YOU CAN NOW SET THE HEIGHT BY SCREWING IN AND OUT. THE COOL THING IS THEY STILL AUTO LEVEL WHEN STARTED AND YOU JUST SAVED OVER A GRAND. YOU CAN PAYPAL ME A NICE $50 TIP
BBRUTON2001@YAHOO.COM
Both of my 2003 S-Type headlight motors run, both lights wiggle up/down, then they both droop. The left headlight is aimed a little higher because I was able to adjust the leveler screw a little. Neither headlight aims high enough to see at night.
Thank you for your contributions! You rock!
i am a new owner and my headlight assemblieswent south, and both lights are in the down position. been told i need two new assemblies. found some on-line for around 400 a piece, but saw something about having to remove the bumper.
anyone have some info on how to replace the entire assemblies? hard?easy? got a quote for $2,700, which seems totally from outerspace.
go to this Link and you will learn how fix the dropping headlamps
I e-mailed the manufacturer years ago and berated their lousy engineering and lack of warranty coverage and, as you probably already expected, got no reply.
Thank you Forum for a great fix !!!!!!
Regards,
Regards,
WTB[NorthEast]: 2004 Vanden Plas Headlight Assembly LH
European_Auto11558
Sep 25, 2015 08:05 PM
1964Daimler
Sep 9, 2015 11:28 AM
