S Type R transmission cooler?
Old Nov 27, 2011 | 09:37 PM
05StrJag's Avatar
Default S Type R transmission cooler?
Does the stock ZF 6 Speed come with a transmission cooler? If not, has anyone installed an aftermarket one to keep the temp nice and cool?
Old Nov 27, 2011 | 10:05 PM
Michael Star's Avatar
It uses the radiator to cool, cost saving device.
Old Nov 27, 2011 | 10:11 PM
05StrJag's Avatar
Most cars do this, obviously doesn't work as well as an external dedicated cooler. You can get a good transmission cooler for $100, well worth it.
Old Nov 27, 2011 | 10:28 PM
I agree, the only downside is when it is cold outside it will take the fluid longer to warm up.
Old Nov 28, 2011 | 03:51 AM
phaelax's Avatar
Any such aftermarket systems that can be disengaged/bypassed for those freezing mornings?
Old Nov 28, 2011 | 09:02 AM
Staatsof's Avatar
Yes! It's a problem too, so if you do this get a thermostat as well.
Old Nov 29, 2011 | 08:10 AM
The Chris X's Avatar
I've added a B&M stacked plate style tranny cooler to both my Jeep and Rover (they both tow a good bit and get off-roaded frequently) and I'm very happy with the results. Prefer the stacked plate design over the tube and fin style. I buy the kit that goes for about $65 from Jegs or Summit. Not very hard to plumb on the trucks. On the S-Type, I'm thinking right behind the grille might be a good spot.
I plumb them in circuit with the OEM in-radiator coolers. This helps get the temps up early on. Then the B&M helps stabilize the temps. Fluid path i use: tranny to OEM in-rad cooler to B&M back to tranny.
Not sure if adding one to an S-Type is really all that necessary though. Would need to install a guage first and gather some data.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
