S-Type R/V Mirror Compass Reset
Old Jan 17, 2008 | 07:26 PM
Montru's Avatar
Default S-Type R/V Mirror Compass Reset
Hi All
I have just bought a 2000 3.0 v6 S-Type, and I have noticed that the rear view mirror compass is almost 180 degrees out, for example when the car is facing due south the compass shows north west.
I have looked in the handbook and can find nothing to relate to resetting the compass.
I am new to this forum and I think it's great.
Any help or suggestions would musch appreciated.
Montru
Old Jan 17, 2008 | 07:42 PM
H20boy's Avatar
Default RE: S-Type R/V Mirror Compass Reset
Woohoo! easy one.
Drive around in a circle, very slowly. Seriously, that corrects it.
H20boy's Avatar
I expect you to go outside now...I realize it's cold, but you must.
Old Jan 17, 2008 | 08:24 PM
Montru's Avatar
Hi
Thanks for your quick reply, I went straight outside and started to drive around in circles, when I started due south was NW and I noticed that the compass does not say SE, S or SW at any time, it goes from north (which is north) to NE, E the goes back to NE then N again (which is south) then NW W NW back to North!!
Montru
Old Jan 17, 2008 | 09:01 PM
Montru's Avatar
I forgot to say it still didn't fix it,
Any Ideas?
Montru
Old Jan 17, 2008 | 10:03 PM
H20boy's Avatar
Wierd indeed. Besides resetting the computer by disconnecting the negative terminal on the battery for 5 minutes (no less), I am not sure why the compass is reading all N. At first I thought maybe a bad LCD, but that's just strange.
A few techs around here, they'll see your post and possibly give you more ideas.
On a positive note, I rarely EVER look at my compass. When I have the nav system going, I can always tell which direction I am going based on that. I know you would love everything in your new ride to work, but if that is the only thing malfunctioning, you're doing well. And after a month or two, you won't even know it's there. Can you turn it off so it doesn't even come on?
Old Jan 18, 2008 | 10:59 PM
Montru's Avatar
Ok Many thanks, everything else is A OK so I can't be too dissapointed, glad I went for the S-type and not the X-type, all I have heard from people who have the X-type is the excessive road noise and body roll on bends etc, this baby is very quiet and sticks like glue!
Montru
Old Jan 19, 2008 | 05:14 AM
FactoryJaguarTech's Avatar
You need to make sure compass is set for correct region also.
doing this out my head, so please be patient if I am wrong. I will look up correct procedure if THI doesnt work.
2 buttons on mirror, one says compass and other is mirror of off.
hold down the compass button until it changes to a c in the display. Then drive it in a couple of circles. I have to work today, so I will look it up and report back.
Old Jan 19, 2008 | 06:20 PM
Montru's Avatar
Hi There is only one button on the mirror, which turns on the auto dim feature.
Montru
Old Dec 10, 2014 | 06:48 AM
fstjaguar's Avatar
Hi,
I have a 2001 S-type and there are 2 very small holes above the mirror on the mounting assembly. The hole on the right side will allow setting the region and the one on the left will call up a calibration mode. Set your region and then calibrate by driving in a circle.
tampamark
Oct 11, 2015 10:03 PM
jessejamestw23
Sep 26, 2015 03:57 PM
aadjei
Sep 25, 2015 03:07 PM
zdrapec
Sep 25, 2015 05:49 AM
