s type smoke/limited power
Old Jan 14, 2010 | 03:40 PM
JOsworth's Avatar
You may be stretching a bit to find some good diesel experience here. For one, I'm sure stating 54 Jaguar means something like a 2004. I'm sure you are referencing the number plate / registration. Since a lot of the users here are from North America, myself included, they won't understand that reference. Also, the diesel cars are not available in North America so our experience with them is very limited. That said, I had a gasoline V6 Chevy behave very much like you stated and they "cleaned" the EGR system and it cleared it up. That was caused by using the wrong grade fuel and caused a carbon build up. Now our current Dodge Caravan (you can chuckle at that, I know those are camping trailers in the UK) had the EGR valve go bad and there was no apparent drive-ability issues. There may have been a loss of MPG, but I didn't measure it. That failure tripped a warning light and recorded a code. Once replaced, the code vanished. I did try to clean it first, and it didn't work. So, it is hard to tell. Has your car tripped any warning lamps?
Old Jan 14, 2010 | 03:45 PM
JagV8's Avatar
You'd be far better off on the UK www.jaguarforum.co.uk
Could it be the DPF? But ask there!
Old Jan 14, 2010 | 04:11 PM
dervdave's Avatar
A DPF gets the blame of many problems by the misinformed but definately isn`t to blame here because the OPs car won`t have one, its only fitted to later models.
Old Jan 14, 2010 | 05:11 PM
jagmadjohn's Avatar
good advice as other's there have had problems with the turbo and yes the DPF dose get (shall we say) undeserved bad press
Old Jan 15, 2010 | 02:06 AM
JagV8's Avatar
Sorry to be proffering an impossible DPF but from what VIN was it fitted?
stanjag
Dec 29, 2024 08:26 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Arne
Sep 4, 2015 07:06 AM
dpappyp
Aug 27, 2015 06:31 AM
