S-Type Speed Bleeders
Old Apr 16, 2018 | 12:16 PM
Volbrewer's Avatar
Default S-Type Speed Bleeders
Anyone know what size Speed Bleeders to get for an '08 4.2 S-Type? I'm pretty sure the rears are 10 mm, SB1010 on the speedbleeder.com/size page. The very helpful lady there isn't sure about the fronts though. I ordered SB8125L, but they're not right - the 8 mm diameter is either right or very close, but the thread pitch is slightly different. A 9 mm wrench fits the bleeders that are in it now. She thinks they may be 5/16". Metric rears, SAE fronts?
Old Apr 16, 2018 | 06:49 PM
NBCat's Avatar
The fittings are all M10 X 1.0.
Old Apr 16, 2018 | 11:45 PM
Volbrewer's Avatar
Sorry, I must beg to differ. I've had them out and measured the diameter with a micrometer. The rears on my car are 10 mm diameter (0.3937"/9.99998 mm) and a 10 mm wrench fits them. The fronts are 0.3135" diameter (7.963 mm, pretty darn close to 8) and a 9 mm wrench fits them. They definitely are not the same on my car. Rear length is 39 - 30 mm, front length is 35 - 36 mm.
Old Apr 17, 2018 | 08:05 AM
NBCat's Avatar
Yes, you are correct, I missed paying attention to the fact that you have a 2008 MY car.
The front fittings on the later cars is M8 X 1.25, so you probably need SB8125L, which is what you already ordered.
Old Apr 17, 2018 | 09:33 AM
Volbrewer's Avatar
Typo in my last post: "39 - 30" should have been "29 - 30". The threads do not appear to match. I tried installing an 8125L in a front caliper - it was going in, but binding more and more the further it went, so I quit before going too far. I pulled it back out and tried to mesh threads of my stock one and the Speed Bleeder and it did not appear that they matched. I may buy a stock replacement and send it to them so they can decide what matches it.
Old Apr 17, 2018 | 10:08 AM
NBCat's Avatar
The bleed screw is VIN-specific, so it can be XR810512, C2C27273 (326mm discs), or C2C27272 (355mm discs).
The last two part numbers are for vehicles with VIN N52048 onwards.
I hope this helps.
Old Apr 29, 2018 | 12:12 PM
Volbrewer's Avatar
For my '08 S-type (which is well beyond VIN N52048) with 326 mm discs, front Speed Bleeder type is SB8125LL, rear is SB1010S. Oddly, the wrench size for the stock front is 9 mm, while for Speed Bleeder it's 8 mm; wrench size for stock rear is 10 mm, but 11 mm for SB part. Whatever, they fit. And they work beautifully and make brake bleeding a breeze. Be advised that they will slowly bleed by gravity, so if you want to take a break while doing the job, be sure to tighten the bleeder. Thanks to SBCat for the very specific and very helpful information.
J_C_R
Apr 2, 2018 11:05 PM
Dr. D
Jun 9, 2017 12:53 PM
Bodyman
Aug 2, 2011 08:55 PM
Dan R
May 21, 2010 06:57 PM
MattSteele
Apr 30, 2010 05:52 PM
