S-Type Trunk Release Malfunction
Old May 25, 2010 | 09:20 AM
emarchetti's Avatar
Default S-Type Trunk Release Malfunction
2004 S-Type trunk will not release using FOB, cab button, or trunk lid button. Will only open with key in trunk. Have looked at the fuse and looks good. I can hear a clicking sound in the rear passenger fender area but nothing from the trunk lid when any of the buttons are pushed. It worked the other day when I opened the trunk in the morning but after closing it and needing it open 5 minutes later nothing. I know others have posted similar questions but did not see any with the clicking sound I hear.
Old May 25, 2010 | 09:39 AM
MyBlackCat's Avatar
Did your valet button get set somehow? not sure about the clicking.
Check the valet, its the easiest first step.
Old May 25, 2010 | 09:52 AM
emarchetti's Avatar
I forgot to mention in my original post that I have verified that the Valet mode is NOT engaged - the button is not pressed in and I have tried the trunk release with the button pushed in and with it out.
Old May 25, 2010 | 12:05 PM
Enthusiast's Avatar
Valet mode? What the hell is that?
Old May 25, 2010 | 12:17 PM
JagV8's Avatar
If you have it, the valet button's in the glove box. Activated and if you also have a valet key (green, I think) then a valet can drive the car but not unlock the trunk or the glove box.
Old May 25, 2010 | 01:00 PM
Mafioso's Avatar
To me it sounds like there is a problem in the trunk harness, specifically going to the release motor
Old May 25, 2010 | 02:08 PM
Jon89's Avatar
Is there any moisture in your trunk in the spare tire / battery well? Even small amounts of water in the trunk of these cars plays havoc with the electronics routed down there....
Old May 25, 2010 | 02:25 PM
emarchetti's Avatar
I hadthe spare tire out while verifying that the fuse is alright and there is no moisture present. Thanks. Any other thoughts?
Old May 25, 2010 | 02:26 PM
emarchetti's Avatar
Could you elaborate on the trunk harness thing?
Old May 17, 2022 | 02:40 PM
1Jaguarguy's Avatar
Default Thanks!
Thank you for the information. I needed to solve this in my mother-in-law's 2002 S Type and your solution solved the issue. I'm a hero thanks to you!
Old May 28, 2023 | 05:15 AM
Mathis7891's Avatar
I have the same problem and the noise is coming from the rear control module
Old May 28, 2023 | 07:54 AM
S-Type Owner's Avatar
You already have one open thread on this problem. It is best to keep only one thread going at a time as it makes things complicated/confusing for forum members to follow multiple threads on the same topic...
BritCars
Feb 28, 2014 03:10 AM
JagJet
Nov 20, 2012 07:43 AM
kksgirl
Oct 4, 2011 06:57 AM
DENA
Oct 15, 2007 07:45 PM
medic235
May 31, 2007 07:56 AM
