S-Type won’t start – PATS error
Old Apr 4, 2010 | 09:07 AM
JagV8's Avatar
Use your other key! If you don't have one.... make sure to get one in amongst fixing this.
AFAIK 15 means the car doesn't know the key so you'll have to have it (re-)programmed into the car.
Don't go messing yourself without doing a LOT (that's a BIG LOT) of research or you'll turn a smallish cost into a huge one. Leave the GECM and all other things alone.
I dread even to wonder why you'd mention the GECM.
The usual cause is jump starting the car (or trying to).
Old Apr 4, 2010 | 09:42 AM
motorcarman's Avatar
The keys are configured to the INST pack and PATS code 15 is "key code not stored in memory (also having 8 key codes already stored in memory) or signature mismatch"
The GECM is not part of the starting/running but the Rear Electronic Control Module controls the fuel pump.
The INSTPK and PTEC module need to 'shake hands' and agree on the key status before the INST pack energizes the starter and the PTEC provides spark and fuel.
2 key minimum is required for programming and all keys need to be present at the time of programming.
You could have a module or wiring fault or just need to configure the key transponders.
bob gauff
Old Apr 9, 2010 | 07:11 AM
JagV8's Avatar
A new ICM and the keys - a job for a dealer. Explain properly what's been done and get a quote. I hope you used an ICM of the same model (engine size etc & year).
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Bones
Sep 8, 2015 08:34 PM
Sprayall
Sep 3, 2015 07:49 PM
