S type xenon Change
Old Aug 10, 2019 | 09:04 AM
trycons's Avatar
Default S type xenon Change
Hello. I Have changed niemal lights to xenons it was plug and play. But when i want to Turn them on it works one to 20 Tiles when i turn on switch. Where can be a problem
Old Aug 11, 2019 | 08:15 PM
Aarcuda's Avatar
I don’t understand “Turn them on it works one to 20 Tiles when i turn on switch.”
Old Aug 11, 2019 | 11:26 PM
jya's Avatar
jya
Bit more detail would be helpful.
Old Aug 12, 2019 | 12:18 AM
trycons's Avatar
They turn on once to 20 attemps .
Old Aug 12, 2019 | 12:45 AM
jya's Avatar
jya
Both or just the one?
Old Aug 12, 2019 | 12:31 PM
trycons's Avatar
Both . They are flashing fir while then They turn off
Old Aug 12, 2019 | 01:19 PM
Joedotcom's Avatar
hi
if you have swapped normal headlights for hid headlights, they dont work, as the wiring is different
for a start the polarity is the wrong way round, your missing relays and the self leveling will never work as the 2 level sensors are missing and the leveling module is also missing
I'm surprised they even worked at all
Old Aug 12, 2019 | 01:21 PM
trycons's Avatar
Yea They work but not always like i said . What i have to do for fix that ?
Old Aug 14, 2019 | 06:10 AM
JagV8's Avatar
Just put back the original ones and if you want brighter then fit brighter bulbs.
Old Aug 14, 2019 | 06:20 AM
trycons's Avatar
So They wont work ? Well i pay not low price for them so i wilk try to mąkę them work . Someone have any ideas ?
Old Aug 14, 2019 | 08:16 PM
jya's Avatar
jya
Yes we know they are not cheap to buy. If you want them to work the way they were designed you need to change the wiring, change the polarity, add the leveling sensors, add the modules, add the relays and goodness knows what else.
That's a huge job and not worth it for many people. If they are in good condition you will have no problem reselling them.
Probably easier to look for an aftermarket HID/Xenon kit that may fit or modified to fit within the standard lights.
Morey
E type ( XK-E )
Aug 30, 2014 11:24 PM
marvin1960
May 24, 2013 08:35 PM
solerunner
Sep 18, 2011 05:18 AM
Afflict
Jul 30, 2010 12:48 AM
Waterwalker
XJ40 ( XJ81 )
Mar 17, 2009 06:43 PM
