Shifting Module
Old Apr 15, 2019 | 05:07 PM
Marquise Williams's Avatar
Default Shifting Module
my 2001 Stype has an issue where it shifts hard between 1 and 2...it kinda hesitates a bit. The dealer said that it is the shifting module. I'm glad its not the actual tranny but What is that? I have never heard of it before.
Old Apr 15, 2019 | 07:54 PM
kr98664's Avatar
I wonder if they meant the solenoid pack?:
https://www.ebay.com/itm/Rebuilt-For...E/361501687427
Are you getting any fault codes? I had a recurring transmission fault code (P0745?) on my '02. This solenoid pack took care of it.
A very messy job, as you have to drop the transmission pan for access and then work overhead. Overall not too difficult, but the hardest part was jacking the car up level on all four corners, high enough to get underneath for the refill procedure. Not a lot of room in back to raise the car and get jackstands underneath, too.
Not sure of your experience level, but a good transmission shop could knock this out in a couple of hours, so the labor charge shouldn't be too bad.
Old Apr 15, 2019 | 08:00 PM
kr98664's Avatar
Almost forgot to mention:
The 5R55N transmission in the early models is a VERY common unit. It's a variant of a very popular Ford transmission, used in several bazillion vehicles. Any competent transmission shop can handle any repairs. You typically wouldn't need the dealer to do it.
rlees
Jan 9, 2012 09:52 AM
Bufcat
Dec 1, 2011 05:21 PM
rothe
Dec 6, 2010 07:55 PM
jya
Oct 15, 2010 01:01 AM
sixpackd
Aug 17, 2010 12:38 AM
