siezed engine
Old Jan 1, 2025 | 10:55 AM
mulutchoker's Avatar
Default siezed engine
2001 4.0 s type.this is my sons car.It developed a oil leak(valve cover and tube seals] motor siezed up.this car is in exelent condition other than that.Are there long blocks or even short blocks (crate motors) avalable for this modle?
Old Jan 1, 2025 | 11:44 AM
NBCat's Avatar
How was the engine diagnosed to determine it was seized?
If the spark plugs have been removed, use a 24mm socket and breaker bar on the crankshaft bolt to try and rotate the engine in a clock direction when viewed from the front of the vehicle.
Old Jan 1, 2025 | 11:50 AM
thanks for the reply.we did just that and it wont budge.im going to fill the cyleders up with wd40 and let it sit.if that dosnt work ill pull the panb and take a look athe crank and rod berrings,wats the chance of finding rebuild parts.
Old Jan 1, 2025 | 11:51 AM
i ment pan not panb,oops
Old Jan 1, 2025 | 12:35 PM
NBCat's Avatar
Here is a source for AJ28 engines:
https://www.jagbits.com/jaguar-rebuilt-engines.html
You might also find a used engine on eBay, but the history is not usually known.
Old Jan 1, 2025 | 06:07 PM
motorcarman's Avatar
https://www.car-part.com
Old Jan 2, 2025 | 01:12 PM
BillSF9c's Avatar
I read, few parts. Jag wants your core to rebuild for their sales as crate used. Good luck. Let us know, plz.
Ice7Burg44VDP
Aug 31, 2024 02:02 PM
DrewH777
Dec 2, 2022 02:05 PM
Jlewis468
Jun 3, 2020 01:18 AM
noterman
Mar 28, 2014 10:28 AM
cometgold
Sep 19, 2009 08:17 PM
