SOLVED! 2k S-Type Misfire Idle issue/gasket help
Old Jan 29, 2008 | 11:20 AM
Dennis's Avatar
ud
Default RE: 2k S-Type Misfire Idle issue/gasket help
I have experienced this problem with other cars, by the way you described it, it sounds like a MAF sensor problem..
Old Jan 29, 2008 | 12:13 PM
FactoryJaguarTech's Avatar
Do you have a scantool of some sort?
Old Jan 29, 2008 | 06:36 PM
Can it show datastream at all? Fuel trims specifically?
Take off the air boot from the throttle body and see if it is filthy?
Also the cat ineffciency code normally would indicate cat failure.
How many miles you have on vehicle?
Can you measure temperature from each tail pipe? Would be better if you have
infrared thermometer and measure cat temp.
Old Feb 2, 2008 | 08:41 PM
jhe2003's Avatar
ORIGINAL: Dennis
I have only seen a couple of these, if everything else if fine(fuel trims,vac leaks, coils, plugs,timing, compr, clean tb)everything, then I will go for the MAF
Old Feb 2, 2008 | 08:45 PM
Dennis's Avatar
ud
Okie dokie..Being the last choice I'd rather be..as these MAFs are probably NOT cheap either
Old Feb 3, 2008 | 11:13 AM
The reason I brought up datastream was for the fuel trims. If when you drive it the fuel trims jump to 20% or so, then I would definitley go MAFS. If not, then more to figure out.
Old Feb 4, 2008 | 06:33 PM
What cold interior problem?
Glad you got running problem sorted.
Old May 1, 2010 | 09:00 PM
lah024's Avatar
Default idle miss in s type
I have 2001 4 liter ith 43000 miles and it has developed a random miss at ile does anone have any ideas
X_Type_South_Africa
Dec 9, 2015 05:37 PM
aadjei
Sep 25, 2015 08:51 AM
Jaleaf
Nov 2, 2012 02:02 PM
Brent
Apr 14, 2012 03:33 AM
lmathson
Mar 2, 2012 08:38 PM
