Speedo discrepancy- anybody else?
Old Apr 13, 2010 | 09:12 PM
Mikey's Avatar
Default Speedo discrepancy- anybody else?
I've noticed my speedo always indicates fast by about 6% or so. IAW, at a indicated 100kph, true speed is 94kph.
I'm running the correct OEM size tires. 235/50/17.
Anybody else?
Old Apr 14, 2010 | 01:25 AM
JagV8's Avatar
Try Test Mode (a search will find it) and see if speed's better there.
Old Apr 14, 2010 | 08:03 AM
Bull27's Avatar
From what I've heard most manufacturers put in a "buffer" on their vehicles, meaning the speedo will show up to 5mph faster than your actual speed. Typically that is why State Troopers give you a 5mph variance. Im not sure if Jag does it, but I will check using my Tom Tom and report back. I put 17"s on my wife's Saab that originally had 15"'s, and much larger tires. Now I am actually going 2MPH faster than what that speedo says according to TomTom, and I think the GPS reading is as accurate as you can get.
Old Apr 14, 2010 | 08:14 AM
carelm's Avatar
Bull27,
I drive based on having a 5%error in the speedo reading. Generally, I go 7 mph over the posted limit to account for it.
Mike
Old Apr 14, 2010 | 08:34 AM
tbird6's Avatar
If you have factory navigation you can go into test mode and display the GPS speed while you’re driving. I found my 2005 STR to be almost completely accurate. It never was off more than 1 mph compared to the GPS!!
Old Apr 14, 2010 | 08:40 AM
VMV's Avatar
VMV
I have the original tires and wheels and my speed difference between the speedometer and my Magellan SATNAV is about 2-3 mph.
Old Apr 14, 2010 | 08:54 AM
Enthusiast's Avatar
My TomTom shows a 5 MPH difference on both cars....
Old Apr 14, 2010 | 09:22 AM
Mikey's Avatar
So it sounds fairly common. My others cars show a much smaller variance- the old plastic fantastic is spot on at all speeds over 30kph and the GF's Honda reads fast by one 1-2%.
I'll try the Test Mode recalibration and see if it helps.
Old Apr 14, 2010 | 09:57 AM
Leedsman's Avatar
Manufacturers have been making their speedos optimistic for years. Commonly 30mph was more like 28mph. Remember when a wheel goes over a 'bump' in the road, it will travel slightly further than if the road were flat, same with a depression. So when you do your checking over a measured mile, you need a reasonably flat road. Years ago I bought an ex-coppers BMW bike; its had a special speedo on it, a Jaeger guaranteed 2% accurate.
Leedsman.
n.b. Don't lose any sleep over it!
Old Apr 16, 2010 | 01:23 AM
mel's Avatar
mel
i have 2000 V8,i was driving with my obd2 connected,odb was reading 60, and speedo was reading 65.I reckon both are fed from the same source.
Old Apr 16, 2010 | 08:44 AM
Mikey's Avatar
Tried the test mode thing, no change. Will be getting new tires soon, I'm curious to see how much difference that makes in accuracy.
Old Apr 16, 2010 | 08:50 AM
JagV8's Avatar
No change? It displayed exactly the same speed?
Old Apr 16, 2010 | 09:54 AM
Mikey's Avatar
Yup, no change. Does the test thing actually recalibrate the gauges, or just do a quick function test- ie supply a voltage to drive them full scale?
Old Apr 16, 2010 | 10:16 AM
JagV8's Avatar
You didn't read up on it? The details tell you what's available, including the speed. See: https://www.jaguarforums.com/forum/s...ode#post185626
Old Apr 16, 2010 | 10:45 AM
Mikey's Avatar
Ah- obviously I didn't read far enough and stopped after ETM test 2, gauge sweep. I'll do 18 and 19 next time out in the car.
Thanks.
Old Apr 16, 2010 | 10:57 AM
JOsworth's Avatar
Mine is checked by the local police department maybe once every couple of years, more if I'm not careful..... Usually done with a remote radar read....
Sorry, couldn't resist.....
Old Apr 16, 2010 | 07:54 PM
Toller's Avatar
I experimented with the Test Mode today. I can get it into Test Mode. When I tap the trip computer button (the one that I used to set the Trip Mode active)....nothing happens except that the left hand window changes to show the next unit being measured. These are the normal measurements.
What am I doing wrong?
Old Apr 17, 2010 | 09:49 AM
Mikey's Avatar
Well, some interesting progress. Went for a drive with the panel displaying 'Met Speed' and compared that number to the analog gauge reading and GPS. Probably not the safest thing to do and I should just concentrate on driving instead.
In any case, the ETM number and GPS are very very close, probably within 1-2% but the gauge reading still lags considerably as indicated in my first post.
Is there such a thing as gauge recalibration that can be done by the home mechanic?
Old Apr 17, 2010 | 10:38 AM
JagV8's Avatar
lags? In your first post you said it was more, didn't you?
Old Apr 17, 2010 | 10:47 AM
Mikey's Avatar
Yes you're right again. Tripped on my own words and the futility of trying to multi task.
The speedo leads (not lags) by the 6% orignally mentioned.
