Speedo discrepancy- anybody else?
Old Apr 17, 2010 | 11:15 AM
JagV8's Avatar
I expect 6% (or so) is deliberate. Most speedos over-read by 5-10%. I think they're not allowed to under-read. I don't understand why you're surprised at yours over-reading.
Old Apr 17, 2010 | 12:21 PM
Mikey's Avatar
Originally Posted by VMV
speed difference between the speedometer and my Magellan SATNAV is about 2-3 mph.
Originally Posted by Mikey
My others cars show a much smaller variance- the old plastic fantastic is spot on at all speeds over 30kph and the GF's Honda reads fast by one 1-2%.
Originally Posted by Leedsman
Manufacturers have been making their speedos optimistic for years. Commonly 30mph was more like 28mph.
That's why.
Old Apr 19, 2010 | 12:41 PM
Mikey's Avatar
In re-re-reading the .pdf file,
http://jaguar.bttlxe.com/xtype
http://jaguar.bttlxe.com/xtype/Addit...%20Cluster.pdf
here's an interesting comment on page 7.
"ETM displayed speed figure will be
approx 3% higher than speed
indicated by speedometer.
Allowed tolerance – minus
nothing/+ 10% + 2.5 mile/h."
Mine is 6%, so I'm double what Jag states. Their comment '+10% +2.5mph' is ambiguous. Does it means 3-10% is acceptable or 10% above 3% is the limit? Or is there another 2.5 mph to be added?
Old Oct 7, 2010 | 07:52 PM
carelm's Avatar
I was playing around with the GPS on my Blackberry and in comparing it to my speedometer reading there was only a maximum of 1-2 mph difference for speeds from 50 mph to 70 mph. The speedometer reading was either slightly higher or dead accurate. I was counting on a 5 mph difference and the usual 5 mph grace which is why I usually go a little under 10 mph more than the posted speed limit. I guess I'd better throttle back a bit, especially since VA is experiencing a budget shortfall.
Old Oct 8, 2010 | 01:31 AM
JagV8's Avatar
Bear in mind it depends on which rims+tires (sizes) you have, how much the tires are inflated, and the setting put into your car for the rim+tire sizes when it was last set (in manufacturing if not done since then). Plus, how worn your tires are.
Old Oct 8, 2010 | 09:03 AM
Mikey's Avatar
I had forgotten about this thread. Over the summer, I had a new set of tires installed. The over-indication of the speed has reduced from 6% to about 3%.
Old Oct 8, 2010 | 12:58 PM
odeon's Avatar
Most of the cars I have owned have over-indicated. My current S-Type's speedo leads by around 5-6% when compared to my GPS. I suspect the tyres are to blame.
RollaJones
Sep 27, 2015 03:31 PM
LnrB
Sep 25, 2015 08:58 AM
carcycle
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
