Squeak at startup
Old Feb 10, 2013 | 08:58 AM
chazaroo's Avatar
Default Squeak at startup
During the last few days, the engine has developed a squeak, squeak, squeak noise when I start the car in the morning. It stops after a couple of minutes. Sound familiar to anyone?
Old Feb 10, 2013 | 08:59 AM
Mikey's Avatar
Dribble some water on the accessory belt. Does the squeak go away?
Old Feb 10, 2013 | 09:04 AM
chazaroo's Avatar
I'll try it. What does it mean if the squeak goes away?
Old Feb 10, 2013 | 09:16 AM
Mikey's Avatar
The accessory belt is slipping and may need to be replaced. The pulleys may be glazed also or the tensioner may be faulty.
Old Feb 10, 2013 | 09:18 AM
abonano's Avatar
+1 on accessory belt.
As Mikey pointed out - ensure the tensioner is working properly - there is a notch in the assembly that should be within the 2 marks. Also, again, all pulleys should roll smoothly and no "wobble" - if either are evident - change the offending pulley out before installing a new belt.
Old Feb 10, 2013 | 09:45 AM
chazaroo's Avatar
Thanks, I'll check in the morning. Too late now as it has already warmed up.
Old Feb 10, 2013 | 10:13 AM
aholbro1's Avatar
If that doesn't turn anything up, better have a look at the crank pulley. The damper can de-laminate and eventually it will either start tossing the belt or shredding it. On the +side, you have probably 3-6 mo between onset of tweeting and belt problems. There is a test involving putting a couple of marks on the pulley and damper but i don't recall the particulars. Search "damper" and that should pop it up. I know there is a good discission of it somewhere in the X300 section, but think it has also been covered here in S-Types. FWIW, I've experienced the failure in both the 7.3L Exc and a 3.0L S-Type.
SD96XJ6L
Jan 12, 2022 04:30 AM
JimC64
31
May 30, 2016 03:04 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
Bcrary3
Sep 27, 2015 12:21 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
